LV8 Table Question
Old Nov 12, 2004 | 08:37 PM
1MoorTym's Avatar
1MoorTym
Default LV8 Table Question
What do the columns 32,48,64,80...208 represent in the LV8 table?
Where can I find out what all the values mean (and do) when using WINBIN to look at bin files?
Old Nov 13, 2004 | 08:49 PM
gbody5's Avatar
gbody5
IIRC the LV8 value is a function of RPM and some other parameters to represent relative load of the engine. So for example if you are at 2000 RPM and at WOT, in the Main Spark Table, the value in the table at the intersection of 2000 RPM and 208 LV8 is your spark advance look-up that the ECM uses.
Conversely, if you are at 2000 RPM and coasting, your scan tool will probably show and LV8 of 32 or 48, and the value at that intersection is the spark advance look-up.
In my stock spark advance table the former is 26.02 degrees and the latter is 48.16 degrees advance.
Make sense? LV8 is used in many tables, think of it as a scale of engine load from idle to wide open throttle, it changes if you are going up a hill or down a hill, cruising, accelerating, decelerating, etc.
Old Nov 14, 2004 | 05:29 PM
1MoorTym's Avatar
1MoorTym
OK, got it, the LV8 (Spark Advance Table) is a static lookup with the columns representing a load calculated by other factors
I'm using WINBIN to view several different BIN files. Is there any documentation around to interpret what the various entires and values mean, and how they interact with each other ??
There's got to be some programming 'how do' for dummies document someplace.
Old Nov 14, 2004 | 06:44 PM
gbody5's Avatar
gbody5
I have never used WINBIN, I understand it is a pretty basic program. I use Turbo-link for my scanning and TunerPro for reading/editing. You can download the basic TunerPro for free, then all you need is the definition file for your ECM (.ECM file) and you're off and running reading your BIN (.bin files).
This should give you a pretty good view of what's in the chip without spending any money for TunerCat, etc. Check out motes.net and thirdgen.org for access to your ECM file and hundreds of BIN's.
Old Nov 15, 2004 | 06:38 PM
1MoorTym's Avatar
1MoorTym
Just spent a few minutes with TunerPro, man does it blow away WinBin, thanks !!
Much easier to compare my stock chip and the custom one now, especially since you can do it on screen, or dump the whole thing out to a text file.
The hunt to decipher what it all means continues
Old Nov 15, 2004 | 06:43 PM
gbody5's Avatar
gbody5
Glad to help, let me know if you have any questions about the tables in TunerPro.
To LV8 Table Question
