coolent leak
Old Nov 15, 2004 | 03:52 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default coolent leak
boy, what am I in for now? Last summer I replaced the water pump on my 85 L98. Now I've got a coolent where the intake bolts to the engine right under the thermostat. I was praying it was the thermostat, but it's not. It's right under it. Any advice would be appreciated.
Old Nov 15, 2004 | 04:02 PM
gbody5's Avatar
gbody5
Sounds like intake manifold gasket.
Old Nov 15, 2004 | 04:10 PM
mikey whipreck's Avatar
mikey whipreck
Some members of the forum would probably cringe at this suggestion- but just add a bottle of stop leak. If your leak is minor, it will patch it up. If you leak is major, it'll buy you some time till you hafta fix it.
I believe later c4's come with stop leak from the factory (the capsule/pill/tablets you add to the coolant).
Old Nov 15, 2004 | 06:03 PM
Cruisinfanatic
What do I buy, Just regular radiator stop leak? I'm putting up for winter in a week or 2. I'll fix in the spring.
What kind of job is the intake man gasket?
Worse than the waterpump I hope not?
Old Nov 15, 2004 | 06:37 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I suspect it is the intake manifold gasket! You have iron heads and an aluminum intake, separated from each other by a gasket. Iron and aluminum don't peacefully co exist and the gasket takes the beating!
IMHO,The "stopleak" is not necessarily going to work since the gasket will continue to deteriorate at an accelerating rate. If you want to try it, it is the Baer pellets. they come six to the plastic card I believe.
If you are handy with tools and have a little time, it isn't a bad job to change it. But it will take time. I think a shop will charge you around $ 300 to do it
Jack
Old Nov 15, 2004 | 06:48 PM
gbody5's Avatar
gbody5
Wow, shop rates must be much lower where you are, they charge nearly $600 for that service around here. I actually used some stop leak in mine when it first started, it lasted several years, probably around 10 thousand miles before it finally blew completely out. I have AL heads though.
Old Nov 15, 2004 | 07:35 PM
88JDO's Avatar
88JDO
Default what a coincidence
I noticed my car overheated when I got to work this morning. Looked like thermostat gasket failed. Got a new one at lunch and replaced it when I got home. Still leaking. Must be the intake gasket! Just what I need, another project.
Old Nov 15, 2004 | 10:46 PM
Trog's Avatar
Trog
Make sure you check the thermo housing itself real close. Mine developed a little crack in the front right above the bolt flange. Replacing it was easier/cheaper than the whole manifold.
Old Nov 15, 2004 | 11:48 PM
mikey whipreck
http://www.barsproducts.com/index1.html
I'd get their product
Old Nov 16, 2004 | 07:21 PM
Cruisinfanatic
I'll definately try the stop leak. If all else fails and I have to change the gasket, it would be a really good time to replace the injectors too I bet.
Old Nov 16, 2004 | 07:23 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
I had the inevitable leak (aluminum heads) at the rear of the manifold. My local shop did it for $375 including parts. He also does rear wheel bearings for $ 130 plus parts and a great 4 wheel alignmnet here is $ 60.00
Send me your vette!
seeya
Old Nov 16, 2004 | 07:52 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Here's my story.... I too started seeing coolant setteling around and on the intake. My C-4 is an early 86 with Iron heads. I just missed the Alum heads on the line by 4 cars. Anyway... It seems that the coolant will weep up the intake bolts and come out around the bolt head and then dump in the intake vallies. This appeared on the passenger side towards the front of the motor.
So..my cheap fix was to get a coat hanger and cut out a straight section and then flatten one end sort of like a blacksmith thing..so it was wide and flat .
Then I managed to get a wrench on the bolts and found they were lose. I tightened them up
Then I put a "U" shape bend in the flatened end and applied some sticky Permatex gasket sealer in the inside of the bend. I inserted the messy gacked up hanger around the bolt head and smeared the permatex around the bolt to manifold area.
This tool enabled me to seal the area where the weeping was.
That was 3 years ago....It hasn't leaked since. And my 86 has the Carrolle Vortec Supercharger system.
Make sure that the intake bolts are tight. They have a tendency to back out.
Old Nov 16, 2004 | 10:24 PM
mikey whipreck
I like your fix, Viet Nam Vett
btw, where'd you find that supercharger at?
Old Nov 17, 2004 | 10:11 AM
Viet Nam Vett
2015 C2 of Year
Here's the Link to Carroll Supercharging...
He has added a new name to his co...
Blowerworks.. Carroll is was the first to offer Supercharger kits for the vett back in the early Eighties. He's is the only one that offers Gasious Injection with his kits.
Spend some time and read about his systems and why he uses gasious injection. You'll find that everyone else jumped on the band wagon after he offered the Blower kits.
His IMHO is the best for the Vette..
http://www.carrollsupercharging.com/
To coolent leak
