Desktop Dyno Favor
383ci - 11.5:1 CR
SCAT 9000 crank, 3.75" stroke - Zero Balanced
Probe Forged 6" Lightweight 4340 Rods
Probe SRS Forged Flat Top Pistons
2.00" intake / 1.56" exhaust
1 3/4" Long Tube Headers
Ported Intake Manifold
Comp Cams Custom Grind .544/.576 230/242 114 LSA
Open: Close:
1 BTDC 49 ABDC
55 BBDC 7 ATDC
Head Flow;
.200 = Intake 130cfm / Exhaust 102cfm
.300 = Intake 184cfm / Exhaust 144cfm
.400 = Intake 229cfm / Exhaust 173cfm
.500 = Intake 259cfm / Exhaust 187cfm
.550 = Intake 269cfm / Exhaust 190cfm
Exhaust Cut-Outs / Flow-Tech Race Readies (straight dumps)
Second Run: (rather than straight dumps)
Magnaflow Mufflers
X-pipe
Third Run; (with the dumps again)
Additional 125hp worth of N20
If any other info is needed, please let me know.
MANY THANKS!!!
Ryan Judd
I don't have Dyno2000 currently loaded onto my PC but will load it tomorrow to get some numbers for you; I may be back with some more questions.
LT1 is the intake I'm using. 3" runners (as usual). I would probably use single plane, just because TPI is calibrated for ~26" long runner of TPI.
MANY THANKS!
Ask any other questions that come to mind, I can't remember anymore of what it asks.
1) 501 chp @5,500rpm; 529 ft-lb @4,000rpm; VEm=96.9 @4,500rpm
2) 478 chp @5,500rpm; 513 ft-lb @4,000rpm; VEm=96.0 @4,500rpm
3) 601 chp @5,500rpm; 719 ft-lb @2,000rpm; VEm=96.9 @4,500rpm
Here I used 108deg as the cam installed angle (forgot to ask you) and small headers on the exhaust.
I used a 100-shot as a 125-shot was not an option and I don't know enough about NOS usage to tweak the numbers.
BTW, using large tube heades brought about 10chp more at the peak but lost 2chp (from 174 to 172) at 2,000rpm.
I'm not so sure how close this sw is to an actual engine dyno but at least it shows trends.
So, I'm beginning to have more faith in the numbers for your motor.
Dyno2000 models a stock TPI very well but how do I model the siamese base or siamese runners, super-ram, tunnel ram, etc. We only have single plane or dual plane to chose from as options.
If you have dyno pulls on your 400cid build maybe you can try various intakes to see what model brings the power curve close to the dyno.
BTW, I think that 15% DT loss is closer to reality with a 6-speed; for my A4 17% DT loss gave the best correlation between time slips and chassis dyno data taken the same evening.
Do you have any direct data for 15% drivetrain loss through a ZF & Dana IFS system?
