injector conversion
Old Nov 16, 2004 | 05:44 PM
99svrcpe's Avatar
99svrcpe
Default injector conversion
what is the conversion calculation?: from pounds/hr to grams/sec.
I was finally able to view my tune from ED Wright.He has my Bosch 30# injectors set at 7.764 gm/s. which appears high since the stock 28#'s were at 3.403 gm/s.
Old Nov 16, 2004 | 06:25 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Not real sure how he came up with the values he did but to convert 30lbs/hr
30lbs/hr x 1 hr/3600sec x 454grams/1 lbs = 3.78 grams/sec
Old Nov 17, 2004 | 04:09 AM
Blower91's Avatar
Blower91
Did you use Tuner Pro or some other program to view the constant? Do you know the Hex-number? I have #30 injectors and my EPROM has 150 hex (336 decimal) at address 841C-841D hex (8D mask, yours might be different).
Old Nov 17, 2004 | 10:08 AM
99svrcpe's Avatar
99svrcpe
I used LT1 Edit OBDII. I was pleasently surprised that I was able to read Ed's tune because I've heard that Ed locksout his tunes from being read.
As many of you may know I have been chasing some drivability problems ever since my rebuild. ie: surging idle, stumble on accelleration, stumble when retuning to idle, knock retard, fauled plugs,
long term trims at 25%, short term trims at 50%. and all along Dave at Ed's was telling me my problem was mechanical and not in the tune.
I've been told by Bryan at Pcmforless that 7.764 gm/s is the equivalent to 60# injectors, I have 30# hence ALL my problems. He recommended I change it to 4.019 gm/s, now the car the car runs great and all those drivability issue are gone.
I'll never use or recommmend Ed wright again.
Old Nov 17, 2004 | 10:53 AM
Blower91's Avatar
Blower91
I agree with Ski that 3.78 g/s is correct for #30, this is what I use in mine too. I think 4.019 is closer to #32. During open loop it might run a little lean, I don't think it would hurt to check this. During closed loop the ECM should be able to handle a 7 % variation... I'm sure someone will let us know if I'm in error.
Anyway, good you car runs great
Old Nov 17, 2004 | 11:04 AM
99svrcpe's Avatar
99svrcpe
yeah...I'm going to play around with some of the numbers...I hope to get it on the dyno soon as well. my long terms are staying at 0% and the short terms are varying between +/- 3%.
To injector conversion
