What about the ZF-6 makes it work?
Old Nov 17, 2004 | 02:36 PM
Nathan Plemons's Avatar
Nathan Plemons
Default What about the ZF-6 makes it work?
Every car I have ever driven you can forget about shifting into reverse if there is ANY forward motion at all. Most cars will easily let you go the other way though. The ZF on the other hand works perfectly. I can be in a parking lot, moving somewhat slowly and put it into reverse while still moving forward slightly and it never makes a noise.
Most tranny's will grind like crazy. Is reverse synchronized too on these things?
Old Nov 17, 2004 | 02:59 PM
Red Tornado's Avatar
Red Tornado
Old Nov 17, 2004 | 03:07 PM
JasonL's Avatar
JasonL
Yes, reverse is synchronized.
Old Nov 17, 2004 | 03:11 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Old Nov 17, 2004 | 03:52 PM
Nathan Plemons
Seems strange that they would go through the extra expense.
Old Nov 17, 2004 | 03:55 PM
HammerDown's Avatar
HammerDown
They're Germans, it's their job to be ****.
Old Nov 17, 2004 | 03:58 PM
FELNGR8's Avatar
FELNGR8
Old Nov 17, 2004 | 03:59 PM
bogus's Avatar
bogus
[cheesy German accent]Ve have vays of making it better.[/cheesy German accent]
Old Nov 17, 2004 | 04:58 PM
Perfusion's Avatar
Perfusion
Funniest thing I've read all week!
Old Nov 17, 2004 | 05:15 PM
Z-07 freak's Avatar
Z-07 freak
Then you didn't see the one about the st. bernard and the poodle in OT?
Old Nov 17, 2004 | 05:46 PM
DaveN355's Avatar
DaveN355
A few years ago I bought a 91 Stealth RT/Twin Turbo (before you flame, it's gone and I have a 94 Vette now!). Long story short, the tranny and transfer case went south. Both were ZF components.
When I looked in the service manual, I found detailed instructions on tearing apart, fixing, and rebuilding the auto transmission and the 5-spd (non-ZF) for the base cars. However, when you turned to the section on the ZF 5 spd transmission, all it said was "non-serviceable component. Replace".
Dave
Old Nov 17, 2004 | 06:41 PM
silver & red CE's Avatar
silver & red CE
maybe because it's a truck trans? (i have no idea, just brainstorming)
Old Nov 17, 2004 | 08:12 PM
Nathan Plemons
If it's a truck trans I'm suprised it's synchronized at all!
Old Nov 17, 2004 | 08:13 PM
scorned1's Avatar
scorned1
Well I must have a bad one then. I have a 96 CE LT4 and If I try to go direct to reverse it will grind really bad sometimes. Before going into reverse I have to shift through 4th and 5th several times and then very gently put it into reverse. Even that doesn't always work and I will get a slight grind. I have a friend with a CE and a Grand Sport and he has to go through pretty much the same routine to get into reverse.
Old Nov 17, 2004 | 08:15 PM
scorned1's Avatar
scorned1
Well I must have a bad one then. I have a 96 CE LT4 and if I try to go direct to reverse it will grind really bad sometimes. Before going into reverse I have to shift through 4th and 5th several times and then very gently put it into reverse. Even that doesn't always work and I will get a slight grind. I have a friend with a CE and a Grand Sport and he has to go through pretty much the same routine to get into reverse in either of them.
Old Nov 17, 2004 | 08:48 PM
bogus's Avatar
bogus
Dave
sure that they were ZF? I read long time ago those were Getrag... and this site confirms it... Stealth Transmission Specs
Old Nov 17, 2004 | 08:57 PM
froggy47's Avatar
froggy47
Replace clutch master & slave. See zf doc web site.
Old Nov 17, 2004 | 09:04 PM
FX GS's Avatar
FX GS
That's what cured mine
To What about the ZF-6 makes it work?
