Err. 22, TPS adjusted, still have Err 22
Old Nov 17, 2004 | 05:04 PM
cyberblast's Avatar
cyberblast
Default Err. 22, TPS adjusted, still have Err 22
Hi
I've got another Vette this week, it's a 86.
The response of the car is strange, and the engine drinks too much of fuel while cruising the city. The Service Engine Soon comes up some times while driving.
I checked for errors and i got Error 22, i used WinALDL to check. The Voltage of the TPS was 0.27. I don't have a Voltmeter, WinALDL told me this, i hope its a possible alternative for checking?
So i adjusted TPS while watching at my Notebook, till i got 0.57 Volts. Then, i disconnected and reconnected the battery to erase the faultcode.
But it still comes up!? Can anyone help me?
I attached 2 Screenshots of WinALDL, the first was with without starting the engine (only ignition key on) and the second one with engine started.
Can you see any problems there? What are you suggesting to do/check?
engine off:
engine on:
Thanks Martin
Old Nov 17, 2004 | 05:17 PM
mikey whipreck's Avatar
mikey whipreck
I would then suspect the wiring to/from the TPS
Old Nov 17, 2004 | 05:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Your TPS still looks a little low.
You need to set the TPS base voltage with the IAC pintel fully extended and base idle set to 450rpm. My method is on my site.
Just to check out my theory here, bump your TPS voltage to around .65-.70 Vdc at normal idle (~800-900rpm) and see if the code goes away.
Old Nov 17, 2004 | 05:42 PM
cyberblast's Avatar
cyberblast
thank you 65Z01, i will try your method and will post an status update.
Martin
Old Nov 18, 2004 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Your IAC #s are very high. Set your base idle and tps one more time.
Here is some info on 22 if you don't have it http://members.shaw.ca/corvette86/Code%2022.pdf
Old Nov 18, 2004 | 08:49 AM
aklim's Avatar
aklim
My IAC is set at about 10-20 counts. After that, I go after the TPS.
You also need to check the TPS with the engine off. See that it is a smooth curve and not a dead spot.
Old Nov 18, 2004 | 04:49 PM
cyberblast's Avatar
cyberblast
I increased first the TPS now to 0.71 (as it was at my last vette), now i don't get the error anymore and the car runs fine!
should i change the IAC now or acting like "never touch a running system"?
Thanks for all your help!
Martin
Old Nov 18, 2004 | 05:27 PM
65Z01's Avatar
65Z01
So long as my warm idle in gear is 600-700rpm I just ignore IAC counts on my scan tool..."if it ain't broke, don't fix it.
Congarts on getting the problem solved.
Old Nov 19, 2004 | 02:57 AM
cyberblast's Avatar
cyberblast
Ok, i will have an eye on it...Thank you very much, one problem less on earth
Old Nov 19, 2004 | 05:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The book says tps .54 volts and no more. To set ,install paper clip in diag a-b and turn on key wait 30 seconds with key on disconect iac at throttle body remove a-b wire from diag center,start engine and run engine up to operating tempeture.
engine should be in gear for auto 450 rpm std 400 rpm.
After engine warmed up shut off engine and reconect iac.
Second set is TPS WITH KEY ON ,use volt meter on the two top conections use a streigh pin through the two upper wires,connect red top black bottom radio shack volt meter about 9.95 the one in the little yellow box.Tps should read .54 volts and engine set.
Old Nov 19, 2004 | 05:48 AM
cyberblast's Avatar
cyberblast
I can't find the IAC, is it located directly below the TP-Sensor?
Old Nov 19, 2004 | 09:48 AM
AGENT 86's Avatar
AGENT 86
To Err. 22, TPS adjusted, still have Err 22
