wheel questiony
Old Nov 18, 2004 | 10:36 AM
rganders's Avatar
rganders
Default wheel questiony
Will the rear wheels and tires (18" x 9-1/2") fit on the rear of my 95 coupe? It has 17" x 8-1/2". Thanks Randy Anders
Old Nov 18, 2004 | 10:42 AM
conv90's Avatar
conv90
Do you have 8 1/2" wide rear rims??
I think a 95 has 9 1/2" rims...
Old Nov 18, 2004 | 11:12 AM
MYCoupe's Avatar
MYCoupe
Are you referring to C5 rear wheels because those were the only ones which were 18x9.5? The wheels and tires will fit. The tires will be too tall and your speedometer and acceleration will be a little bit off.
Old Nov 18, 2004 | 11:26 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
You can fit a wider rim under there if you'd like also. The ZR1 rims were 11" wide so you shouldn't have any problems with what you are wanting to do.
To wheel questiony
