Chasing down knock counts
Old Nov 18, 2004 | 12:10 PM
TankerVette's Avatar
TankerVette
Default Chasing down knock counts
Okay, we gonna figure out whether its false knock or not...
...with my trusty TunerCat and Datamaster by my side.
2 Possibilities with Causes:
-False knock
*Bad Knock Sensors
*Noisy valve train (bad lifter?)
-Real knock
*Too much spark advance (why would this be? it was fine before the mods...)
*Slight increase in compression due to thinner head gasket
*Bad gas (Very unlikely, I use Chevron 92 Octane)
2 Areas to isolate:
-WOT
-Normal Closed Loop
Experiment 1: Turn off knock retard and see where and how the knock is occuring
Did this last night. Gonna analyze the data today...
Would appreciate any thoughts... Hope I'm not being too boring...
Old Nov 18, 2004 | 12:58 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette?
Under what conditions do you detect knock retard?
Old Nov 18, 2004 | 01:15 PM
TankerVette
Darn, gotta get that into my sig...
'95 AT, 81,000 miles...
Old Nov 18, 2004 | 01:45 PM
CFI-EFI's Avatar
CFI-EFI
I don't know much about the LTx engines. Is it possible to adjust base timing on those? I'm thinking not. Either way, you may want to try revving it in neutral and looking for knock counts. Especially with your good (too good?) gas, it should not detonate in neutral, indicating any such counts are false.
RACE ON!!!
Old Nov 18, 2004 | 02:04 PM
TankerVette
Damn! Thanks CFI-EFI! Love simple experiments!
Old Nov 18, 2004 | 03:20 PM
ittlfly's Avatar
ittlfly
RACE ON!!!
No adjustments possible on base timing on the LT-1. All ECM controlled. Weh problems develop that can be a royal PIA.
Old Nov 18, 2004 | 03:21 PM
ittlfly's Avatar
ittlfly
RACE ON!!!
No adjustments possible on base timing on the LT-1. All ECM controlled. When problems develop that can be a royal PIA.
Old Nov 18, 2004 | 03:40 PM
LPDesRoche's Avatar
LPDesRoche
I suggest a LT4 knock module. No matter what the outcome of your situation you will more than likely need one. The LT1 module is very sensitive. LT4 module takes into account the noisier valve train.
Old Nov 18, 2004 | 07:03 PM
CFI-EFI's Avatar
CFI-EFI
That's what I thought. When I checked mine for false counts, I used good gas, set the base timing to zero, and revved it in neutral. I know the counts I got were false, because it could never knock under those conditions. Even with non-adjustable timing, it shouldn't knock in neutral.
RACE ON!!!
Old Nov 18, 2004 | 09:19 PM
TankerVette
okay, first chunk of data analysed from experiment ...
over 1/2 hour drive, knock occurs:
-Closed Loop
1400-2500 RPM
85-100 MAP
-WOT
no knock except during initial throttle tip-in
2 experiments tonight:
-Take 3 degrees of advance out for 1400-1600 RPM/80-100 MAP
-Do the CFI-EFI experiment when I get home...
Results tomorrow...
Old Nov 18, 2004 | 09:58 PM
Lone Ranger's Avatar
Lone Ranger
Your sig says timing set by GM performance. Does this mean your spark advance tables have been editted to be more aggressive? The stock GM numbers in the spark advance tables are already pretty aggressive. At most only another two degrees on the upper end, wouldn't really change the tables if it were me. If anything you should restore them to stock. Let me know if you need a stock PCM bin image in Tunercat for '95 Vette, equipped with auto trans (and 2.59:1 rear). I have one saved from my car I think. You could use it as a reference or baseline, using the 'compare' function in Tunercat.
Old Nov 19, 2004 | 03:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
With any mods I would use the LT-4 knock sensor.
The knock sensor is cheap only about $29.00.
If you are running roller rockers the counts will be around 30,th and you will pick up a high knock count at around 1300 rpm why I don't know ,but it will appear as if the counts started around 1500 check it .
I changed my eEGR table to 120 it was at 126.See if that helps,
I have been chasing knock counts for a while and have given up.
The engine has a safe guard in it and will retard weather you try to change it or not.
I run NOS so that is why I was chasing the knock until I gave up.
Old Nov 19, 2004 | 07:02 AM
conv90's Avatar
conv90
-Closed Loop
1400-2500 RPM
85-100 MAP
-WOT
Results tomorrow...
It seems real knock
Another way to check is to set the graph on datamaster on TPS , map and retard due to knock.
If at every substantial change of load (and TPS) you notice knock retard, this is real knock retard.
All of us are hoping that our knock are false!
many times (instead) the knock is real.
How many deg the ECM pull out?
-Beppe-
To Chasing down knock counts
