AIr Pump Delete Question
Old Nov 18, 2004 | 09:07 PM
WNDOPDLR's Avatar
WNDOPDLR
Default AIr Pump Delete Question
I am in the process of installing TPIS headers on an 88. So far things are going reasonably well. My question concerns the air pump set up. Can I just remove all of the hoses and electrical connections from the air pump and disconnect the whole works, leaving the air pump in place, without setting off all kinds of codes or creating problems. Eventually, I will install the idler pulley and remove the air pump all together, but that is a little ways down the road.
Old Nov 18, 2004 | 09:13 PM
mikey whipreck's Avatar
mikey whipreck
You can do that-
you won't throw codes.
In addition you can "Quiet" you AIR pump (basically gutting it).
There is a tech tip on this page of how to do that
Old Nov 18, 2004 | 09:14 PM
mikey whipreck
double post
Old Nov 18, 2004 | 10:36 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by mikey whipreck
You can do that-
Yep, took out the AIR stuff, EGR and installed headers. No codes. That plus I did gut the AIR pump so now it is just basically a pulley. Looking forward for the AIR pump eliminator bracket from forum member korvette4u as we speak
An added bonus to all of this is that water pump changes are now much more simpler, heh, ask me how I know
Old Nov 19, 2004 | 08:11 AM
WNDOPDLR's Avatar
WNDOPDLR
You can do that-
Thqanks for getting back to me so quickly. I am new to the forum but this is just a super resource for info. I think I am hooked. Hope I can repay the favor sometime.
Old Nov 19, 2004 | 06:23 PM
TankerVette's Avatar
TankerVette
anybody know if this will work (EGR, AIR pump delete) on a '95 with no codes?
thanks
To AIr Pump Delete Question
