C4 Rear End U Joint Problema
Old Nov 19, 2004 | 12:15 AM
84GSCLONE's Avatar
84GSCLONE
Default C4 Rear End U Joint Problema
I HAVE AN 84 GS CLONE AND FOR SOME REASON MY REAR PASS SIDE HALF SHAFT KEEPS GOIN THROUGH NEW U JOINTS ... COULD IT BE THAT IT WAS INSTALLED POORLY? OR THESE REAR ENDS HAD PROBLEMS? ANY HELP WOULD BE GREATLY APPRECIATED
Old Nov 19, 2004 | 12:26 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
You really should not TYPE in all caps. It is seen as your yelling.
Old Nov 19, 2004 | 12:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
WHAT?
Old Nov 19, 2004 | 02:43 AM
bogus's Avatar
bogus
inner or outer? I really couldn't hear with all the yelling.
Old Nov 19, 2004 | 05:38 AM
84GSCLONE's Avatar
84GSCLONE
hahaha you guys are crazy ... caps is yelling? thats something new to me ... i could never tell the way a person is typing something whether its a joke or serious or whatever .. i usually type in capitals ...
my first u joint was next to the rear pass wheel ... then it was the one towards the center ... and i just had my rear pass wheel u joint changed and i know the center one is going out as well pretty soon ... when i start driving her i have to get that done ... by that time i will have done the LS1/T56 swap completed
Old Nov 19, 2004 | 07:18 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
If i had that problem id be YELLING too
Old Nov 19, 2004 | 08:57 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you had a 4 wheel alignment lately?
How is your wheel bearing ?
Are your bushings shot ?
Old Nov 19, 2004 | 10:25 AM
Sawbone's Avatar
Sawbone
What is the part number and brand of u-joints you are using?
How are you diagnosing it as a u-joint?
What did the bad u-joints look like when you removed them?
Old Nov 19, 2004 | 11:00 AM
scorp508's Avatar
scorp508
Check your wheel bearings for play. They'll eat up u-joints like no tomorrow if they are out of spec.
Old Nov 19, 2004 | 05:09 PM
84GSCLONE's Avatar
84GSCLONE
THE U JOINT HEADS WERE ALL LOOSE LOOKING LIKE THEY WERE GOING TO COME OFF. KRAGEN BRAND WHICHEVER THAT IS. I DONT HAVE THE BOX ANYMORE. I'LL LOOK INTO THE BEARINGS. THANKS FOR THE HELP FELLAS!
Old Nov 19, 2004 | 05:12 PM
bogus's Avatar
bogus
ugh... get Spicer ujoints... that could be part of your problem.
check the bearings - if they are bad, funny things can happen.
also, make sure the alignment is good.
Finally, make sure that halfshaft isn't bent!!!
Old Nov 19, 2004 | 07:28 PM
Sawbone's Avatar
Sawbone
You should be using spicer u-joints. Call up these guys and they will get you what you need.... http://www.tomsdifferentials.com/
If you haven't changed the bearings I would suspect them as a possible culprit
To C4 Rear End U Joint Problema
