No backup lights
Nov 20, 2004 | 08:35 AM
No backup lights
First I checked the fuse, then I even checked the bulbs. Any one know what I should check next?
Nov 20, 2004 | 08:46 AM
Next would be the switch. Not sure how to get at it on your year though
Nov 20, 2004 | 09:27 AM
OK, I'm an idiot, what "switch"?
Nov 20, 2004 | 09:56 AM
The switch on tranny or shifter. Not sure where though. When you put it in reverse it triggers the switch.
Nov 20, 2004 | 02:03 PM
What year? Manual or Auto?
Nov 20, 2004 | 02:07 PM
96 LT4, sorry I guess that would be important.
Nov 20, 2004 | 03:26 PM
Quote:
If it is an auto, the switch is on the shifter under the boot.
Nov 20, 2004 | 03:32 PM
i have a 91 6spd and also have this problem. were would it be for my car??
Nov 20, 2004 | 05:52 PM
Quote:
Yours is on the drivers side screwed into the tranny. Before you do anything else, jumper the switch out to make sure its bad.
Then get ready, because its expensive and a real pain to change !!
Nov 20, 2004 | 06:03 PM
Nov 20, 2004 | 11:14 PM
problem was all the lamps burned out on mine ,all 4 of them on my 88
Nov 21, 2004 | 05:24 PM
Scott , I'm guessing it is the switch on the tranny. This is a common problem but I don't think it is hard to fix. good Luck, Guy
Nov 21, 2004 | 06:50 PM
It's not that bad to change. mine took a poop @ 20,000 miles
3 monts out of waranty
Nov 21, 2004 | 09:21 PM
Just out of warrantee...that had to suck! And thanks to everyone for the advice.
Nov 22, 2004 | 01:26 PM
I have an 85 4+3, where would the switch be at on my car ? thanks
