help with 86 LCD unit
Thanks for any help
Steve
Last edited by ses86vette; Nov 21, 2004 at 11:19 AM. Reason: OK, Now where are these light bulbs at
I just replaced mine last week. Very easy to do.
Take out dash cluster-
Place on a soft cloth face down-
Remove bolts holding metal shielding in place and remove it-
Remove bolts holding top circuit board in place and remove it
CAREFULLY, and evenly on all sides.
You will see the small plastic clips holding the lcd backlights.
Remove the one that isn't working, go to PepBoys and pickup
the replacement bulb. (Generic bulb, don't ask them for an LCD
dash cluster bulb as they will look at you crosseyed). Show them
the bad bulb and they shoudl have it in stock. (Failry common,
and I paid $2.49 for 2 of them (Extended life).
I look for these bulbs at every parts store I go to. I've yet to see one. Sylvania 882. Nuke, are you sure you didn't put in 194s? I've been told they're lower wattage, but if they do in fact work, let us know.
Thanks for any help
Steve
Ok. They are :
SYLVANIA 194LL (Long life Instrument / Side marker)
fits perfect, works perfect.
ps. I don't think they, or the originals even were halogen. They aren't nearly bright enough to be halogens I think. But I'm sure..
The 882 lamp has two straight pins that go into a socket and the 194 uses a flattened wire loop that would have to be straightened away from the body of the lamp in order to attempt to plug them into the socket. Also, the 194 wire leads are not very stiff and it would be difficult to insert both wires into the socket, not to mention that the socket's springy contacts will not be spread and you will not have a reliable connection to the socket. The 194's are lower power lamps and won't hurt the cluster dimmer circuit. If they work and you don't mind that they can't get as bright, then you should be ok.
PS. If you do touch the 882 lamp installing them, just wipe them with a Q tip and alcohol to remove your skin oil.
Ok. They are :
For anyone that uses a 194, did you have to unwrap the wires to make two little prongs or did you just slide them in?
ks for the bulbs I feel I'm getting screwed. For that cost-if I don't like em I can throw em away.
