can these headers work with an lt1 ?
Old Nov 22, 2004 | 12:48 AM
reed62783's Avatar
reed62783
Default can these headers work with an lt1 ?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33631
i know its probaly a bad idea. but can these be put on a 92 ?
<---- looking for cheap way out
Old Nov 22, 2004 | 12:52 AM
bogus's Avatar
bogus
I don't think there are bolt differences... what might be off is port shape...
I don't see why they would not fit, as far as the car is concerned... but the bigger issue is engine compatibility.
Old Nov 22, 2004 | 12:56 AM
chriswtx's Avatar
chriswtx
I may be wrong, but those dont look like C4 corvette headers to me. I have alot of pics on my computer of different brands and none look like those.
Old Nov 22, 2004 | 12:58 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
They're the cheap Hedmans and can be had for about $120 from the big mail order speed shops. Hedman makes much better versions of these with heavier pipe, thicker flanges and even ceramic coating. They'll fit any C4 but these have no emissions hook-ups. They do make emissions versions but only for the L98s. There is also a slight mismatch with the D-port heads found on all LT1/4s and later L98s.
Old Nov 22, 2004 | 01:19 AM
zelement's Avatar
zelement
I don't think its a good idea to buy cheap headers.
1st. Installing long tubes are a true pain in the *** already and if they are not designed properly you can spend countless hours fitting them. 2nd. Once you have them on you have to worry about the ports matching and sealing, you are better off with stock manifolds then to have a leaking header off the exhaust ports.
3rd. changing spark plugs with a poorly designed header is probably more frustrating than anything.
4th. cheap headers will not last as long as more expensive headers, therefore you have to replace them soon after.
If you think you can deal with these issues then go for it.
Old Nov 22, 2004 | 01:27 AM
chriswtx's Avatar
chriswtx
Look at the #2 and #6 exhaust tubes. Imagine trying to change those spark plugs...
Old Nov 22, 2004 | 02:49 AM
Corvette Kid
Actually, if those are the Hedmans, as I believe they are, the plug and wire fitment is pretty good. Although you can't tell from the picture, those pipes come outward a good way before they turn down giving good clearance. It's really a shame they don't make an LT1 specific header. Their Elite series is a good header and not deserving of the bad rap that they get due in part I suppose, to the fact that they do make the ultra cheapies too.
Old Nov 22, 2004 | 09:10 AM
kman0066's Avatar
kman0066
Well, I can attest to using the cheap hedmans. YES, CHANGING PLUGS IS A PITA. I recommend removing the headers for plug changes, otherwise you'll be using a 5/8" wrench to remove the plugs because you can't fit a socket onto the plugs.
Would I go back and spend 4 to 5 times as much for better headers, no. Four times as much, come on. Yes the quality of these headers is poor but compared to the price of others, you can change them yearly and still come out ahead.
But if you do get the Hedmans cheapies, be prepared for difficult maintenance, they are not for the newbie to install or work with. Some custom brackets are in order also if you're not handy with a grinder and welder.
Old Nov 22, 2004 | 09:44 AM
88BlackZ-51's Avatar
88BlackZ-51
why would u wnat 2? those are garbage, and will rust leaving your engine bay to look like u know what............
Old Nov 22, 2004 | 10:08 AM
LD85's Avatar
LD85
I have never seen them on a Vette, can you post or email me pictures of them on your car? I dont beleive anyone has posted Headman pics.
BTW, back in 1965, Headmans were the "cats a$!" on my dad's 65 Nightwatch Blue 65 GTO 4-speed with 3 dueces,
Old Nov 22, 2004 | 10:56 AM
mikey whipreck's Avatar
mikey whipreck
I personally wouldn't buy used headers...
but as far as the "cheap" hedmen comments:
Why do you call them cheap? Many on this forum have them and like them. The elite series are, as one person said, excellent, and I'd put them at the top of the list of headers...
As far as "cheap" I would name Hooker as the cheapest, due to quality, fitment and primary size... but then again, this is just my opinion
Old Nov 22, 2004 | 11:42 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Those don't look like they would fit to me.
Old Nov 22, 2004 | 12:00 PM
Nathan Plemons's Avatar
Nathan Plemons
Except that they fit perfectly and have excellent quality. I've had several guys running TPIS headers look at my "cheap" Hooker headers and start whining about how much money they spent on such poor fitting junk.
Old Nov 22, 2004 | 04:48 PM
Corvette Kid
I've got the cheap Hedmans (68440) on mine right now while I'm waiting on another header and don't find plug installation to be that bad. Some I can do with a socket and rachet, some with a socket and wrench and only one that requires a 5/8" offset box end. No big deal really, as headers go. The wires fit great and with 90 degree boots on all wires, none are close enough to worry about burning the boots. The only thing I would prefer was different on them is a slip fit collector and if I were keeping them, I'd just cut off the lip and make them so. If I tire of waiting on the other header, I may just replace them with the same header in the Elite version. The configuration is identical on all part numbers for C4s according to Hedman tech.
Old Nov 22, 2004 | 05:13 PM
redbullapril23's Avatar
redbullapril23
ok my 2 cents!
I put the same ones on my 1996 lt1
now yes they fit the engine!
BUT NOT THE CAR
now I had to do alot!!!! of custom fabbing. Im sure some people will disagree. but seriously its jsut trouble!!! a 7 hr job turns into a 30 hr puzzling job! the headers wont fit right on the pass side without removing the evaporator core shroud!
also oil dip stick wont fit right, it has nothing to hang onto..no bolt. the bolts are almost impossible to get on! and wont fully tighten!
its just one problem after another.
seriously buy better headers!
and make sure you get them ceramic coated!
email me if you need them coated! I am giving CF members special prices, just email me
Slimshaby@mindspring.com
thanks your friend/vendor
Sean Blanton
mikey whipreck
hmm... you must be one of the lucky one(s). -primary size is an argument for another thread
Old Nov 22, 2004 | 05:31 PM
BLUE ONE's Avatar
BLUE ONE
Yes they are hedmans.
Yes they are cheap
Yes they do require some work to get them to fit well
Yes i would buy them again
yes i would get them coated
If you are able to trial fit them and do a bit of fab work they are a good buy.
if not go for the dearer bolt on ones but i couldn't recommend where from.
i picked up 2 tenths on my 90.
The 1"5/8 pipe worked great on my combo
cheers Mark
To can these headers work with an lt1 ?
Old Nov 22, 2004 | 06:50 PM
Corvette Kid
Originally Posted by redbullapril23
ok my 2 cents!
BUT NOT THE CAR
Sean Blanton
Sean, with yours being a '96 and mine being a '95 the cars are virtually identical as far as this subject goes. Mine fit with no real clearance issues anywhere. Some of the bolts were a bit close to the pipes but with just a light pry between the bolt and pipe after screwing them in part way, I had adequate clearance to tighten them with a quality 3/8" box end wrench for the ones that couldn't be tightened with a socket. As far as the dipstick goes, I just used a cushion clamp and small bracket and secured it to the block in an unused hole down a little lower. The left side brackets I haven't fitted yet because as I said, this may be a temporary situation but the checking I did showed there would be only minor fabrication required to hook them back up should I decide to stay with a Hedman. I guess maybe we're at opposite ends of the tolerance overlap for the product. It happens.
Old Nov 22, 2004 | 06:54 PM
Nathan Plemons
Being that Holley is here in BG I know LOTS of guys who run Hooker Headers. There are never any fitment issues, at least on a straight car. On friend in particular had trouble making them fit his f-body but it turns out the frame on that car was so screwed up that it essentially drove down the road sideways. If you actually use the hardware that comes with the headers they are very easy to get along with.
Just throw out the gaskets that come with them and use real ones.
Old Nov 22, 2004 | 06:59 PM
jdawgC4's Avatar
jdawgC4
Do another search on ebay I saw a corsa exhaust system with headers. It is at $430 right now. Not sure if it is actually all corsa but prob worth checking out if its what you are looking for.
