code 32...see inside
Old Nov 22, 2004 | 04:56 PM
korvette4u's Avatar
korvette4u
Default code 32...see inside
got my first code... for a long time.. get this ....there is no egr circuit ,, it was removed over 18months ago...as matter of fact nothing is there..
so what gives?....
temp 194 for winter is all i replace this weekend.. did nothing else.. car seems to run and idle ok.
87 L98...
Old Nov 22, 2004 | 05:11 PM
subman's Avatar
subman
I have been plagued with the same code for some time now on my 91. I have done some searches and found:
Your 88 has a temp sensor located on the top of the EGR tube (right side of engine next to the dist.) If the wire is broken, stripped and grounded, porcelin cracked or some other malady, code 32 shows up. Same thing on the EGR solenoid. If your EGR valve has a leak (check this with a vacuum pump and a small mirror) code 32.
I'm not sure on the 88, but a free flowing exhaust (removed precats, free-flow cat, free flow mufflers) eliminates some backpressure that is necessary for the ECM to read the EGR stuff.
Check the search engine for "egr - code 32" and read all the posts.
Good luck -
Old Nov 22, 2004 | 06:02 PM
korvette4u's Avatar
korvette4u
Good luck -
no temp sensor ....no egr tube.... egr valve plugged and no connection to it.. running headers so no tubes. no solenoid...the complete egr system has been striped..(wires disconnected as per forum instructions)like i said no codes until today...i have reset ecm.. yet to test drive. (busy building air eliminators brackets)
what i did was replace heater core(had to remove ecm), then replaced thermisthat with 192, (had 160 before)...seems to runn fine ...threw code this morning while driving in -1 weather....
Old Nov 22, 2004 | 06:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The ECM does not call for EGR till coolant temp is above 175deg F and you just installed a higher temp T-stat....
You still have the command line from the ECM to the EGR solenoid and the feedback line from the EGR temp sensor. All you need to do is install a diode or relay between these two lines so that when the ECM calls for EGR it "sees it", or you can have the EPROM changed to avoid calling for EGR.
Old Nov 22, 2004 | 06:43 PM
korvette4u's Avatar
korvette4u
...Ok that explains it!.....i have no way of programing epprom YET...so : egr temp sensor is the cermic thing-ajig just below distributor (passengerside...also, it isn't ther. but the wire is)...now where exactly is the diode (4148,or 4001 are these diodes ok to use)connected? to the wire that leads to sensor then to ground? which way is the doide installed? i assume the doide is the easier of the two (relay)?
"command line from the ECM to the EGR solenoid and the feedback line from the EGR temp sensor" .....there must be some knida color code for the wire...zes just don't ya hated when you how to fix it, but without specific detailed instruction, " priceless"
To code 32...see inside
