i was thinkin about cruzinperformance for a rebuild, but what if some of them leak in the pressure test. does that mean the injector needs to be replaced or can it be fixed?
Any 22lb injector, Ford or accel, will work. And you dont need a chip for stock size injectors. Any larger and you will need the chip retuned or an adjustible fuel pressure regulator and turn down the pressure.
