Got an oil pressure question????
Old Nov 23, 2004 | 08:50 AM
Alcee1's Avatar
Alcee1
Default Got an oil pressure question????
Oil pressure is at 80psi, when I first start it up, cruzin', highway, idle, it just stays at 80psi, I know this is not normal. What do you think the problem is?
Old Nov 23, 2004 | 11:58 AM
CFI-EFI's Avatar
CFI-EFI
The sending unit is not sending, for one reason or another. With the wire disconnected the gauge defaults to the maximum reading. The sending unit may be bad, or you may have a faulty connection.
RACE ON!!!
Old Nov 23, 2004 | 01:56 PM
#70SM2's Avatar
#70SM2
Default The sending unit is not sending
I had the same problem a couple weeks ago after the new transmission was installed. While installing the new tv. cable the mech. pulled the wire off the oil preasure sending unit, right behind the distributer. Had to pull distributor cap to put it back on.
Old Nov 23, 2004 | 08:06 PM
Alcee1's Avatar
Alcee1
Thats funny, i just had my new tranny installed not to long ago, I will check it out friday, thanks guys....
Old Nov 23, 2004 | 08:56 PM
FD2BLK's Avatar
FD2BLK
A bad ground will also cause the problem
To Got an oil pressure question????
