Pedal soft after front pads replacement
Old Nov 24, 2004 | 02:11 PM
gpagaduan's Avatar
gpagaduan
Default Pedal soft after front pads replacement
I swear, I didn't touch anything else. Does depressing the caliper get air into the system? Never had this happen before. Bled them out and they're almost back to the same firmness. Safe enough to drive anyways.
Nathan Plemons's Avatar
Nathan Plemons
Could just be the type of pad you used.
Old Nov 24, 2004 | 02:34 PM
1stC3Vette's Avatar
1stC3Vette
If you did not have the rotors turned, it could be the wear-in period of the new pads. Most likely, it is that the rubber seals harden over time and when you relaxed the seal by depressing the caliper, some air was allowed to enter the system. Now that you have bled them, everything should be ok.
Good Luck.
Dino
To Pedal soft after front pads replacement
