Bad Bearing?
Bad Bearing?
Hello everyone, i've been reading about all the great performance mod's we can do to our cars and would like to thank everyone for the great idea's. I think I may have a rear wheel bearing (right rear) going bad and was wondering if someone could give me an idea as to the symptoms and or visual ques to look for. I noticed a squeaking/ scrubbing noise that would come and go at intermittent times yesterday. Thanks in advance for your help.
Jack up the R/R and grab the tire at 6 &12 o'clock location. Try to rock the tire in and out. Movement there would incicate a bad bearing. Also, check the u-joint by applying pressure with a screw driver at its trunion. There shouldn't be any movement there either.
Good luck.
Good luck.
Good luck.
Good luck.
You really only have to remove 6 nuts and 5 bolts per side. I just did this last night. We had the driver's side done in about an hour. For whatever reason the passenger side took a lot longer.
The worst part about the whole job is that sometimes you can get a ratchet on the bolt but you don't have enough room to actually turn it and break it loose, very annoying.
I went out and checked for freeplay in the wheel bearing and there was none, "whew" so i'm gonna start looking at the u-joints as I noticed a bit of popping when first pulling out of the driveway. Thanks guy's.
A popping noise could also be an indicator of a slightly loose torque arm. Take it out on and give it a pretty heavy amount of throttle and watch the shifter. If it moves any significant amount you need to tighten the torque arm.
Mine go so loose one time that at wide open throttle the trans would come up and hit the bottom of the car!
