Porting the Plenum and going 52mm tb do or don't?
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
My mods are listed below in my signature. I have gone to a larger 2.5 rear Y-Pipe, Hi-Flow Cat, K&N open lid w/k&n filter and big mouth air dam. Iam breathing a little easier...so my question is....will my car benefit at all by going 52mm on the tb (thinking of sending mine out for rebuild) and Iam doing my injectors so while the plenum is off...should I take and port my plenum?
thanks
jeff
thanks
jeff
NCM Bash 2008-2018
well actually...
If I just went to port the plenum then no your right...it wouldn't cost much.....but.....if I do this it will....so how do you feel now? This is what I had in mind?
http://forums.corvetteforum.com/show...p?p=1548953729
