superram porting
Old Nov 26, 2004 | 04:10 PM
rugby!'s Avatar
rugby!
Default superram porting
i just bought a superram setup from tjwong on monday. can i work on porting it myself? do i need to port it, i don't want to put it on without porting it, if porting it will make a big enough difference? can i port it with a demel? and what addaptor part should i use, and grit sandpaper?thanks.........
Old Nov 26, 2004 | 07:59 PM
vetluver's Avatar
vetluver
You can use a Dremel but stay tuned for a long sit. It doesn't have the torque that a die grinder has. Save yourself a lot of time, get an air compressor and a straight and a angled die grinder. I also did a google search for a porting and polishing set and it had everything that I needed for years.
Rob
Old Nov 27, 2004 | 08:59 AM
LD85's Avatar
LD85
http://forums.corvetteforum.com/show...highlight=port
To superram porting
