Wheel offset... What determines it??
Old Nov 28, 2004 | 12:25 AM
darkman5001's Avatar
darkman5001
Default Wheel offset... What determines it??
What exactly is different in 84-87 vettes that makes the offset different of that on an 88-96 vette? Is it the rotors? This offset thing is really racking my brain. Thanks!
Old Nov 28, 2004 | 10:20 AM
Dr_737's Avatar
Dr_737
id like to know as well. Currently putting C5 5 spokes on my Polo Green C4. Just waiting for the powder coat
Old Nov 28, 2004 | 02:30 PM
darkman5001
Wow, nobody knows the answer to this???
Old Nov 28, 2004 | 03:00 PM
c4cruiser's Avatar
c4cruiser
Believe it is in the design and size of the control arms after 1987. The 84-87 cars use 38mm offset wheels and the 88-96 cars use 56mm offset. The 88 standard wheel was a 16" size and the 17" wheels were an option but the offset was the same for both.
The hat thickness of the rotors is different over the same years but the diameter changed at the same time. That may be because of the differences in the suspension.
Old Dec 23, 2004 | 08:27 PM
INTEC's Avatar
INTEC
1st Gear
Default Wheel Offset
Imagine you are sitting in front of your car, and you can see through the bodywork, and into the suspension. Draw an imaginary straight line from the center of the upper ball joint through the center of the lower ball joint, to the point where this line intersects the ground. The distance from this intersection point to the centerline of the wheel, as that centerline is projected vertically from the centerline of the wheel to the ground, is the offset. If the centerline of the wheel is outboard of the contact point of the imaginary line and the ground, this is positive offset. Negative offset is the other way around. This is what an old MGA SCCA racer from the '50 once told me. Can't say if it's true or not.
Old Dec 24, 2004 | 02:12 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
From what I understand on offset is the amount of rim (wheel) back spacing. A 38mm has less back space than a 56mm rim.
The way that they figure the back space is, say a 11" inch rim, get the centerline point which is 5.5". They add the 5.5" and the 38mm, and the rim lip say 1/4" = total back space.
This would mean that the 84-87 mounting position (rotor) is more inward than a 88-96
To Wheel offset... What determines it??
