diff fluid change...How to?
Old Dec 1, 2004 | 01:47 PM
TankerVette's Avatar
TankerVette
Default diff fluid change...How to?
Did a search, nada...
How do we go about this?
Old Dec 1, 2004 | 02:14 PM
bogus's Avatar
bogus
Easy, really.... you will need a small hand pump (I recommend the mighty-mite from Pepboys (about 10.00); a floor jack and jack stands; waste oil bin; assistant to hold hoses (just easier); big-assed pipe wrench.
1) raise car
2) crawl under car with big-assed pipewrench. On the passengers side of the diff, you will see a bolt with a tag on it. THAT is the target. Apply the big-assed pipewrench to the bolt and turn. You see, the bolt is tight, and space is limited, the big-assed pipewrench is quick and space efficient.
3) Using pump, remove all the old fluid.
4) Using pump, pour in 2 bottles of GM Differencial Additive. Yes, 2 bottles. That is the recomendation of Gordon Killebrew.
5) Top off with standard 75-90 gear oil (I think that's it, don't remember for sure, but it's something like that). when the oil starts dripping out, you know its about full.
6) reinstall bolt using big-assed pipewrench.
7) lower car, done.
I can do this in about 20 minutes. No kidding.
Old Dec 1, 2004 | 02:23 PM
TankerVette
thanks, man... any way we could get that into tech tips?
Old Dec 1, 2004 | 07:57 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
1) raise car
7) lower car, done.
When did GM change from an Allen wrench fitting to a pipe fitting on the diff? Just curious!
On my 88 a standard Allen wrench removes and reinstalls the plug easily
seeya
Old Dec 1, 2004 | 08:31 PM
STL94LT1's Avatar
STL94LT1
seeya
Don't screw up the diff plug with a pipe wrench, when it is designed to be removed with an allen wrench.
Old Dec 2, 2004 | 01:52 AM
bogus's Avatar
bogus
yea, well, that bitch is on tight, and an allen can be hard to get in there...
a big-assed pipewrench is much easier.
so what if the edges get mangled a bit? I am after effiency here!
Old Dec 2, 2004 | 05:38 AM
84GSCLONE's Avatar
84GSCLONE
I'd go the safeway ... ALLEN WRENCH ... no subsitute for the perfect tool to get the job done right... not quick...
Old Dec 2, 2004 | 07:31 AM
onedef92's Avatar
onedef92
Cruise-In VIII Veteran
You could still use a breaker bar (i.e. section of metal pipe) over the proper allen wrench and have the best of both worlds. That's how I removed my knock sensors using a box-ended wrench...
Old Dec 2, 2004 | 07:44 AM
runner140*'s Avatar
runner140*
Default Or........
Take your vette to Jiffy Lube-----hand them your plastic and thats about it AND done in under 20 minutes. Just an alternative, hahaha.
To diff fluid change...How to?
