Horsepower opinions
-ported and polished LT-1 heads
-Comp Cams 503 cam- 224*/ 230* at .05"
-1.6RR
-LS-1 springs
-new Opti
-Coyle true double roller timing chain
-Meziere electric water pump
-new AC Delco plugs, taylor wires
-Vortex Air Rammer intake with airfoil
-Borla mufflers
I don't have full length headers due to well...I'm getting married and my fiance doesn't see that as a priority
Anyway, I figure about 360 horsepower at the wheels with this setup on a proper tune...any opinions?
http://web.camaross.com/forums/showthread.php?t=322381
my cam is a 224/230 .544 w/ 1.6rr
i havent changed my gears out yet and i have a 2.59 so i havent seen the benefits yet.
i figure something like this at flywheel
300 stock
30 heads
50 ish from large cam
15 from 1.6rr
10 from mezierre
somewhere around 400 at crank is my guess. i called comp and talked to them they said with a proper tune maybe even closser to 150 from these mods.
Depending on your cylinder heads, I give it 350 at the wheels tops in current configuration. With long tubes and free flowing exhaust 400 shouldn't be a problem.
The dyno tech and my engine builder both said it should be about 350 at the wheels...properly tuned. I wanted to see if I could get an unbiased opinion on that. I am eventually going to run long tubes, but getting a good set with installation is pricey. I just got my vette in August, and have dumped mucho $$ into it. Long tubes and a proper tune will get me up with the big dogs......time and money....money and time....
Thanks Nathan, you know your shizit.
1) Who's doing your work?
2) Are you dynoing at Dynotech in Eastlake? I was always under the impression that Steve had LT1Edit onsite. I wasn't sure if you bought the sofware for yourself, but I always thought he had it available for onsite tuning.
Good luck. Sounds like a very nice car.
Ron
We need to go out cruising sometime when the weather breaks in the spring....
That's were I want to be, but I'd be happy with high 300's at the wheels.
I have heard of Rottie. I'd be interested in checking his place out at some point. I know Steve and am good friends with Shane over at Dynotech. They're good guys.
Definitely in on the cruise in the spring. I hate this fricking weather here and this is only the beginning.
Cheers!
Ron
This is with factory exhaust manifold......EM longtubes are going on over the winter.....should pick up ?????hp
I think the CompCams 503 is a good choice, it is what I went with....
BTW Rottie did my work......I am very pleased with his work...
If I make a change to my car it would be to make it run better On The Street or Track I could care less about how much HP its making..
I know Ralph built his motor from the bare block up (I helped by handing him tools)
He has run 11.0x through STOCK LT1 mufflers & never had that motor or car near a dyno.. the same goes for Chris (Insanity) with his 93 LT1 he too is a low 11 sec 120+ mph car & had not seen a dyno..Honest to God, I'm NOT throwing flames at anyone!! but do people dyno just for bragging rights ? I can & do understand the needs for putting an engine or car on a dyno.. i.e. a race motor, or a company that builds parts (heads, cams, etc.) but why the every day driver?
Ralph, Chris, myself & many others race almost every week during the summer, & had never had our cars on a dyno..
Am I missing something
I've heard the saying you cant see the forest because the trees are in the way....Is that my case here...
Look at my ET & MPH.. I Honestly have No Idea How Much HP my car is making...
Thanks to you or anyone who can enlighten me on this subject..
And the second reason to dyno your car...it makes a nice conversation piece!
