ok well i have posted on here a few times about my recent problem with running rich. it happened when i got an exaust leak. i got the leak fixed and it still ran rich. actually it wont even stay running most the time if the rpms are low. well i went to autozone and there were like 3 diff possible reasons for the code 43. one of which being bad o2 sensor in left exaust- makes since i had left exaust leak.
so i replaced the o2 sensor today and disconnected the batery to reset the computer. started it and got check engine light. i tested the code by using a paperclip. and got code 12, 16 , 43. i know code 12 is a start code.
code 16 shows to be the opti or low pulse something. i have never had a problem with the opti and this is weird b/c it wasnt there a few days ago and i havent driven it at all.
code 43 could also be the throttle adjustment screw ( says the guy at autozone).
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Originally Posted by reed62783
what do you mean clear the code? how do i do that?
Well some say you disconnect the negative battery terminal for a 15 minutes or so but this has never worked for me. I have always cleared codes out with a handheld scanner. www.autoxray.com
wow i think i might have thought of something-
ok the code 43 is a knock sensor. The day i got my car in the shop for the exaust leak i ran outa gas and had someone rbing me some. i put about 5 gallons into it. this gas was 87 octane. Is it possible that using 87 octane gas could cause the code to trip and cause the car to run like crap?
i am going to the gas station and getting some 93oct tomorrow along with some octane booster to try it.
the cheap gas could cause that, I guess, but if it does, that means the knocksensor is bad.
think about, the knocksensor is designed to retard timing if the gas isn't hot enough. you put in the wrong gas, it knocks, the sensor can't deal with actually working, then you get a code.
As I stated earlier, your concern should be the 16, the low res code from the Opti. I have seen code 16s and 43s going together. If a code 36 pops, then you are uber screwed, new opti is needed.
ok i put some new gas in the car and some octane booster. i then reset the computer and the code 16 disappeared. leaving only the code 43. i found out that code 43 is deffinatly the knock sensor.
my question now is how long will it take for the new gas to only be in the system. the car was on reserve when i did this.
is it possible for their just to be a bad knock sensor, or does the signal mean something is wrong internally?
