Help!! -- Clutch Issue
Old Dec 3, 2004 | 03:34 PM
rsauron's Avatar
rsauron
Default Help!! -- Clutch Issue
I have a 85 with the 4+3
Last night to it out drove around everything was fine..
parked it in the garage when I got home..
Today I get in it.. I push the clutch in to start it..
and the clutch goes to the firewall with no resistance except for like the last inch..
I noticed that if I pump the clutch resistance builds..
So.. I
Check the fluid level of the clutch... Fine.
next..
I start it up drive around the block.. shifts fine through the gears
come to a stop.. No resistance again.. cant even take it out of gear..
"runaway corvette" shut it off... start pumping the clutch again.. resistance comes back.. start it up and get it back home..
check the fluid level again... Low now..
My thought clutch master cyclinder went bad.. seals..
feels like the same when brake cyclinder goes out..
Any thoughts on this guys I need to get it running ASAP..
Thanks for the help.
Old Dec 3, 2004 | 03:47 PM
bogus's Avatar
bogus
you need new hydraulics.
That's the only answer here... I hope the hose isn't bad, cause that can be hard to get.
Old Dec 3, 2004 | 03:49 PM
rsauron's Avatar
rsauron
well.. I dont think its leaking from any hose.. I mean there is no puddle of clutch fluid on the floor or anything..
Old Dec 3, 2004 | 03:52 PM
bogus's Avatar
bogus
then its blowing out of the slave.
Old Dec 3, 2004 | 03:59 PM
rsauron's Avatar
rsauron
how do I know which is bad the master or slave?
Old Dec 3, 2004 | 05:08 PM
bogus's Avatar
bogus
you would see fluid coming out around the master.
the slave? it would be covered in fluid.
Old Dec 3, 2004 | 05:19 PM
rsauron's Avatar
rsauron
would you replace whichever is bad.. or would you use a rebuild kit on it.. I mean its seals only probably right?
Old Dec 3, 2004 | 05:32 PM
bogus's Avatar
bogus
I would hope it's only seals, but you will have to hone the surface smooth again.
I *think* you can get rebuild kits for the early C4 slaves...
Old Dec 3, 2004 | 06:52 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
How many miles on the clutch?
Old Dec 4, 2004 | 01:06 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You have a leak, 99% it's a bad cylinder.
Don't drive it like this. I nursed mine like this before buying the new master cylinder, and killed my synchros (because of the clutch not disengaging all the way when shifting)
Even after a few gear oil flushes to get all the metal shavings out of the 4 speed, it still shifts hard, and pops out of 3rd gear at high rpms.
If you remove the clutch hose from the slave cylinder, you need to buy new bronze crush washers from GM to put in there, or it'll never seal.
To Help!! -- Clutch Issue
