LT4 Conversion Kit with Hot Cam Emissions
Old Dec 6, 2004 | 08:19 PM
tvetta's Avatar
tvetta
Default LT4 Conversion Kit with Hot Cam Emissions
Guys,
I need help here. I was ready to order and they told me that the kit will not meet emissions?
I live in northern Ky and they test for emissions!
What is the deal?
I know that I am not the only one out there needing to know this.
I was planning on installing this on a stock LT1 with stock exhaust.
Help!
Old Dec 6, 2004 | 08:40 PM
silver & red CE's Avatar
silver & red CE
As long as you have the factory cats even with the LT4 HOT cam, you'll pass the hardest emission test (IM240, aka the rollers).
Old Dec 6, 2004 | 10:08 PM
C4Crazy787's Avatar
C4Crazy787
What year LT1?? If you get a good tune you should be fine.
Old Dec 6, 2004 | 10:19 PM
the blur's Avatar
the blur
do a search on the impala SS forum. there is a lot of HOT cam info there.
Old Dec 7, 2004 | 12:19 AM
tvetta's Avatar
tvetta
1994
I thinking of using tjwong a member!
Old Dec 7, 2004 | 12:29 AM
VenkmanP's Avatar
VenkmanP
Originally Posted by tvetta
Guys,
"They" were just telling you that it is an "off-road only" accessory, which is what they have to say to cover their butts. The LT4 heads and probably the cam come from GM with notices on them about being off road only.
That doesn't mean they won't pass emissions. People pass in CA with Hot Cams on LT4s. KY emissions are a lot easier.
Old Dec 7, 2004 | 12:52 AM
tjwong's Avatar
tjwong
Guys,
What is the deal?
Help!
Your car with a hot cam kit should pass emissions in your state. I am sure we use the same or very simular test methods and hot cammed cars here pass easily. Just as long as you have the convertors intact and working I don't see a problem.
Old Dec 7, 2004 | 07:18 AM
tvetta's Avatar
tvetta
Thanks for the help guys.
Old Dec 7, 2004 | 10:54 AM
tjwong's Avatar
tjwong
I forgot to mention that if there is ever an issue with the car not passing. I can tell you a couple tricks that work well to get it through. If I can get a 572 CID 620 HP crate engine to pass emissions in an 86 pick up without cats I know I can make your hot cammed LT1 pass easily
Old Dec 7, 2004 | 11:02 AM
Fubar569's Avatar
Fubar569
i'm not even gonna ask how you managed that one, but damn fine job!
To LT4 Conversion Kit with Hot Cam Emissions
