LPE 219 cam spec?
Old Dec 6, 2004 | 08:25 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default LPE 219 cam spec?
Does anyone have the specs to this cam @.050", .200", lift and lobe separation?
Old Dec 6, 2004 | 09:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
From LPE's book on the 74219 cam:
219/219deg, duration at .050"
.503"/.525", lift
112deg LSA
Maybe you can get the numbers at .200 from LPE but more interesting would be the duration at .000" lift.
Old Dec 6, 2004 | 09:07 PM
88BlackZ-51's Avatar
88BlackZ-51
.503"/.525", lift
112deg LSA
funny thing is jim, there site says .525/.525 and with 1.6's it is .560/.560.
maybe the book is a type o?
Old Dec 6, 2004 | 09:20 PM
JUAN J SANCHEZ
I remember seeing .525" .525", but I'm mostly interested in the #@.200 to see how aggresive the lobes are. Thanks for the info!
Old Dec 7, 2004 | 09:00 PM
85vet's Avatar
85vet
Cruise-In V Veteran
219 cam card spec
Valve adj ---------- Zero lash then 1/2 turn
-------------------------1.5 ratio rockers ------1.6 ratio
------------------------- intake / exhaust------int / exh
Gross valve lift------------.525"/ .525" ---- .560"/ .560
Duration @ .006" ------ 280deg / 280deg
Duration @ .050" ------ 219deg / 219deg
Lobe Lift -------------- .350"/ .350"
Cam Lobe Center --------- 112deg
Intake center line -------- 108deg
Valve Timing @ .50" ----- open / BTDC ------- close / ABDC
-----Intake------------------ 1.5deg --------- 37.5deg
------------------------ open / BBDC ------- close / ATDC
-----Exhaust------------ 45.5deg ----------- -6.5deg
Old Dec 7, 2004 | 09:12 PM
Raistlin's Avatar
Raistlin
different timing events on the card in this thread...
http://forums.corvetteforum.com/show...t=219+cam+card
Old Dec 7, 2004 | 10:01 PM
85vet's Avatar
85vet
Cruise-In V Veteran
You are right - they are different, mine was done by Erson cams and has 6deg at straight up per a discussion with another forum member.
All I can say is - the card came with the cam!!!!!
Old Dec 8, 2004 | 06:48 AM
JUAN J SANCHEZ
Thanks again guys for the info! I'll try to make something out of them I pretty much got an idea on the specs, but I'm looking for #'s @ .200". Thanks again!
Old Dec 8, 2004 | 11:41 AM
Corvette0096's Avatar
Corvette0096
I know the duration is 218 on both ends, Not 219
To LPE 219 cam spec?
