What could be causing this error code???
Old Dec 6, 2004 | 09:38 PM
LT4BUD's Avatar
LT4BUD
Default What could be causing this error code???
I have had DTC P0152, which is Circuit High Voltage, Bank 2, Sensor 1 come on 4-5 times now.
I have put in 4 new oxygen sensors & the code has set twice since then, so I doubt if it is a bad sensor....
Seems the code sets maybe about 2-3 miles down the road after a cold/cool engine start......could be related to going closed loop????
This has only happened few times, so it usually does NOT happen..
Could this be indicative of a bad injector or something else?????
Old Dec 6, 2004 | 11:29 PM
96GS#007's Avatar
96GS#007
Intermitent connection or shorted wiring. Time to start wiggling and checking all the wiring
Old Dec 7, 2004 | 05:07 PM
mikey whipreck's Avatar
mikey whipreck
which would possibly kill the 02 sensor...
Old Dec 7, 2004 | 07:17 PM
LT4BUD's Avatar
LT4BUD
Autotap shows the O2 sensors to be pretty active........could be intermittent though.....
To What could be causing this error code???
