Why ?? Frame Question ??
Old Dec 7, 2004 | 01:02 AM
CHBING76's Avatar
CHBING76
Default Why ?? Frame Question ??
Why Does The Left Tire Look Pushed Over!(standing In Back)more Then The Right ,bent Frame ??? (stock 1984 W/stock Wheels ) Is This O.k.??
Old Dec 7, 2004 | 01:14 AM
Wayne88's Avatar
Wayne88
My .02
Bent frame means it was in a bad accident--Was it???
Maybe a bad wheel bearing, jack it up & try the 12-6 o'clock test, see if theres any play.
Old Dec 7, 2004 | 01:39 AM
JCAIRE2's Avatar
JCAIRE2
Are you referring to how one tire is sticking out from the body a little more than on the other side? If so, it's a known characteristic of c4's and there is no fix for it, it's just a quirk. If you mean that one tire is tilted on the vertical axis, more than the other side, you need an alignment.
Old Dec 7, 2004 | 12:54 PM
CHBING76's Avatar
CHBING76
Thanks JCAIRE2, i was referring to how one wheel is sticking out more from the body on one side. This is good news ! Thanks again
Old Dec 7, 2004 | 03:10 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
There were also two different bearing for vettes. If someone replaced it with the longer version it would stick out further.
I only remember this from a post I read a long time ago, maybe that person will chime in
Old Dec 8, 2004 | 09:56 AM
4GTWRK's Avatar
4GTWRK
I have found that every C4 is different from installing S/T Frames. The space between the inner body and the frame rail is never the same. It appears that the bodies were just set on the frame and where ever the glue dried, that's where it ended up, usually a 1/2 to 3/4 of an inch off from side to side.
Dave
To Why ?? Frame Question ??
