I'm considering a hot cam and doing the install myself if its just putting it straight in like you pull it out. Does it require degreeing and if not, when is degreeing required. Trying to build upon my knowledge.
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
ZZZASY
'96 LT4
Yes it does. Degreeing simply means that you are going to verify that the installed position of the camshaft is correct relative to the position of the crankshaft. This is very important because the timing of the valve events in relation to piston position is crucial if maximum power
production is to be achieved.
Also you can advance or retard the cam to postion the powerband at different protions of the RPM range. If you advance the cam... the power output will be positioned more at the top end of the RPM range... retarding the cam will put more grunt in the low end.
Actually... the above statement may be incorrect... or backwards... someone else chime in an correct me if I'm wrong. I'm pretty sure that the stock LT4 cam is set at 4* of retardation... similar to the way I operate
HAVE to and want to are two different things. Is it a good idea? Yes absolutely. Can you install it without doing so? Yes. The LT4 Hot Cam in particular is designed to be installed straight up. Provided that GM ground the cam correctly, you don't have to degree it.
When you degree the cam all you are doing is verifying that the cam grinder made it right. If you want to take that on faith you can install the cam without degreeing it.
I've degreed every cam I've installed lately (4 to be exact), they have all been comp grinds. My big rumpety nitrous grind cam (.744 and 273 at .050) was a full degree off, 111 instead of 112 but the others were within a half of a degree. On a street car, I wouldn't go to the trouble of buying a degree setup.
Kwik ta, I'm like you, kinda forgetful but I seem to remember that to improve low end you advance the cam but it's been a while since I've done this.
ZZZASY, If you are going drag racing then by all means degree the cam. If your just building a street engine then I wouldn't go to the expense and bother of degreeing. I just installed a Comp cam in my 85 straight up and it's just fine. Just my .02
ZZZASY
'96 LT4
NO!
It is the same as with with bearing clearances in a new engine. If you implicitly trust that the bearing bores in the block are within specs, the bearings are properly made, and that the crankshaft is perfect, there is no need to check clearances.
If you trust what the cam manufacturer has supplied you with, and the other components that go into proper cam timing, there is no need to to check it. But if you CARE about what goes into your engine, and that it is right...YOU WILL!
ZZZASY
'96 LT4
There is really no need to degree it unless you want to know exactly where it is in the engine. I have installed four of these in F and Y bodies and have never had a problem. The cams are ground by Crane for GM, at least all indications they are. Most of the cams that are in the GM Performance catalog are ground by Crane.
