update- 92 lt1- problems- please help
Old Dec 8, 2004 | 03:48 PM
reed62783's Avatar
reed62783
Default update- 92 lt1- problems- please help
ok well i posted a few days ago about a code 43 on my 92. i replaced the o2 sensor and connector today and code went away but it didnt fix my problem. ill describe the prob again
when the car is under 1k rpm it stumbles badly. even when driving if u can get going. i can hold the gas at 1k and it stumbles to 500. if i let it idle (around 500-600) it sill stumble and die. anything above 1k and it runs fine.
The car is also running extremely rich. all this happed a week ago when i got my exaust leak fixed. the guy also readujusted my 1.6 roller rockers.
any idea?
i am so tired of not being able to drive it.
Old Dec 8, 2004 | 03:49 PM
Nathan Plemons's Avatar
Nathan Plemons
Sounds like he got your rockers too tight.
Old Dec 8, 2004 | 03:52 PM
reed62783's Avatar
reed62783
would that cause it to stumble? and not idle
Old Dec 8, 2004 | 03:55 PM
Nathan Plemons
Quite possibly. If your rockers are too tight the valves will be held somewhat open. This causes a lack of compression, it can cause hard starting and terrible idle / drive characteristics.
I've run into very similar problems myself over the years as I've fought with adjusting rockers. I've finally found a method that works for me.
Old Dec 8, 2004 | 03:59 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Yes it will do that. I know from experience.
Old Dec 8, 2004 | 04:00 PM
mikey whipreck's Avatar
mikey whipreck
Why would you replace the 02 sensors if you threw a code 43?
Old Dec 8, 2004 | 04:18 PM
reed62783's Avatar
reed62783
typo- lol i meant knock sensor
Old Dec 8, 2004 | 04:38 PM
mikey whipreck
ah okay
i agree with the others... the rockers are probably your problem...
Old Dec 8, 2004 | 06:03 PM
ittlfly's Avatar
ittlfly
Just for fun..check your line from the canister purge solenoid to the intake. If the canister is purging a@ idle or there is evidence of the charcol pellets, it will cause your symptoms. Its probably a long shot tho.
Old Dec 9, 2004 | 02:11 AM
reed62783's Avatar
reed62783
any other ideas?
Old Dec 9, 2004 | 06:40 AM
John Robinson's Avatar
John Robinson
Default Cliche
There an old saying among us old time mechanics. Low speed miss is valves high speed miss is ignition. It still applies to the new sophisticated cars. your valves are to tight.
To update- 92 lt1- problems- please help
