Rear Window Defogger
Old Dec 10, 2004 | 04:40 PM
JohnOH327's Avatar
JohnOH327
Default Rear Window Defogger
Having a problem with my 91 coup rear window defogger. When I push the button to turn it on, the light comes on for about 2 seconds and then goes out. Defogger is not working. I checked the connections on the window and struts. Is this a problem in the switch or a broken wire somewhere? Thanks, John.
Old Dec 10, 2004 | 05:02 PM
bogus's Avatar
bogus
I would think the relay is bad.
do you hear a loud click or something?
Old Dec 10, 2004 | 11:42 PM
JohnOH327's Avatar
JohnOH327
I don't hear a loud click from any of the buttons
Old Dec 10, 2004 | 11:43 PM
JohnOH327's Avatar
JohnOH327
Where is the relay?
Old Dec 11, 2004 | 08:12 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by JohnOH327
Where is the relay?
On my 86 it's behind the center I/P
There is also the circuit breaker in the fuse panel
Old Dec 13, 2004 | 07:28 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check the silver relay in the fuse panel box. It's marked.
They have a tendency to work themselves loose and create a short circuit condition. That fixed the problem in my '92.
To Rear Window Defogger
