Hurst shifter install.......HELP!!!!!!
Old Dec 12, 2004 | 02:43 PM
TM-Z06's Avatar
TM-Z06
Default Hurst shifter install.......HELP!!!!!!
Ok - I have the Hurst shifter 89% installed - the gearshift rod is on the gearshift shaft - now I have to get the retaining pin back into the hole. - How in the world do I do that? I can't get anything near that pin in order to push it down.
Old Dec 12, 2004 | 04:02 PM
Strick's Avatar
Strick
If I remember right, you can push the retaining pin out and reinstall it from the bottom.
Old Dec 12, 2004 | 04:53 PM
LD85's Avatar
LD85
Old Dec 12, 2004 | 06:34 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I think I installed the pin from the bottom as well, with needle nose pliers. But it has been a while since I put mine in. I did drop the exhaust for better access. It is worth the aggrivation in the long run!
Old Dec 12, 2004 | 07:44 PM
TM-Z06's Avatar
TM-Z06
Thanks for the suggestions - I had gotten to that point, so the last thing I was going to do was take the shifter out to get the pin out. I ended up getting creative and using a small screwdriver to get it partially in, then using a long slim socket to force it in the rest of the way. Getting that lower boot properly installed..........well let's just say it's on there.
So far I love the feel and throw of the Hurst,
Old Dec 12, 2004 | 07:54 PM
Tony.96LT4's Avatar
Tony.96LT4
The more you drive it the better it gets.
Old Dec 12, 2004 | 08:45 PM
Strick's Avatar
Strick
This is true. It's the best mod I've put on my Vette.
Old Dec 12, 2004 | 09:43 PM
wake's Avatar
wake
I gotta get me on of those!!!
Old Dec 12, 2004 | 11:04 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
That is how I had to do it. It was a major pain!!!
Old Dec 13, 2004 | 10:22 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
That lowr boot and me got issues with each other but I'm still standin and its on there. Lets just say I was glad there were no little kids around when I did mine. They woulda learn a lot of new words.
Other than that you will love the Hurst!
Old Dec 13, 2004 | 11:50 AM
TM-Z06's Avatar
TM-Z06
- I know exactly what you mean. I cursed the Corvette engineers, the ZF engineers...heck I even cursed my wife and dogs. I can't imagine the mindset to come up with some of the lame things on this car. They definitely didn't have the "do-it-yourself" guys in mind.
Old Dec 13, 2004 | 12:06 PM
Nathan Plemons's Avatar
Nathan Plemons
I feel your pain. I've done the same thing installing the B&M, twice actually.
B&M or Hurst, either one has to be better than stock.
To Hurst shifter install.......HELP!!!!!!
