Wheel refinishing \ powder coating
Old Dec 13, 2004 | 01:52 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Default Wheel refinishing \ powder coating
Okay... I tried searching for this... but could not find any useful info on this. I have a set of sawblades that I wanted to use for race rubber, but I noticed that they have a funky corrosion on the polished lip and the painted finish is rather gross. So here is my list of questions
1. what type of finish is on the wheel. It is a silver finish, but is it painted or powder coated from the factory?
2. Realistically speaking... how much work is it to powder coat the wheels?
3. Is there a lot of prep work for powder coating for painting?
4. Do I need to sandblast the finish off or can I just scuff the surface with some sand paper and be ready for paint?
If anyone can provide a link, if this has been discussed, I'd appreciated it. TIA
Old Dec 13, 2004 | 05:50 AM
Atok's Avatar
Atok
I can't comment on how difficult they are to powdercoat but you should strip the old paint and clearcoat off before you do anything. I used Tal-Strip 2 aircraft stripper with excellent results. You'll end up with bare aluminum wheels which you could paint, clearcoat, or powdercoat. I polished mine and didn't re-clear them.
Old Dec 13, 2004 | 10:05 AM
Glasman66's Avatar
Glasman66
I just ahd a whole set powder coated for $100. To have them sandblasted and coated you should be looking at $40 a rim.
Old Dec 13, 2004 | 05:17 PM
84Coyote's Avatar
84Coyote
Is the process something they could do in a day? I have the magnesium 98 rims and I'm wondering how they'd looked polished without the silver paint.
Old Dec 13, 2004 | 05:31 PM
JCAIRE2's Avatar
JCAIRE2
Could be done in a day, but you'll pay extra for the convenience. Usually about 4 day turnaround.
Old Dec 13, 2004 | 09:52 PM
kwik_ta's Avatar
kwik_ta
What are the exact steps? I already have the stuff needed for the powder coating (sort of)... I need to know how to prep the surface. I have a sand blaster too... but the 17" wheels won't exactly fit in the cabinet.
I guess I should ask if I'm better off sending the rims off... selling them... or doing the work myself?
Isn't there a member that does coating and cryo work?
Old Dec 13, 2004 | 10:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Powdercoating can be done in a day, but only if you bring them clean wheels. If they have to clean them for you(most won't) it will take longer and cost more.
A guy on my route quoted my $150 for four wheels.
Old Dec 13, 2004 | 11:07 PM
onebighitter's Avatar
onebighitter
I do all my own powder coating and the powder coating itself takes a few minutes to spray on the powder and about thirty minutes to bake for each color, thats all. The metal has to be clean and bare otherwise the powder will not stick to it.
Old Dec 14, 2004 | 01:15 AM
TerryMathews's Avatar
TerryMathews
Are they really magnesium? I know the other Corvette wheels that were really made out of magnesium (Dymags) had to be painted, to keep the magnesium from breaking down.
To Wheel refinishing \ powder coating
