89 Engine Gremlin / Problem Solved !!
Old Dec 15, 2004 | 01:49 AM
karnivor's Avatar
karnivor
8th Gear
Default 89 Engine Gremlin / Problem Solved !!
installed new fuel injectors, (ACCEL), and new EGR valve.
multiple starts and stops, its purring like a kitten !!
AND .........
(of course.... the)
maf sensor ( remanufactured )
burnoff relays
idle air controller
pcv valve
fuel pump
fuel pump relay
fuel filter
fuel pressure regulator
thermostat
oxygen sensor
spark plugs & wires
distributor cap & rotor
ignition coil
ECM
ignition module
temp sensor (to ECM)
maf sensor (new)
TPS sensor
that I also replaced ......... didn't hurt !
praise God ........ and hallelujah !!
and thank you........ forum members for your input !
and now,......... on to the cure for cancer, this should be easy.
karnivor
Old Dec 15, 2004 | 04:55 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Haha, just think of it all as really really good preventative maintenance too!
Old Dec 15, 2004 | 09:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nothing like a cheap fix
To 89 Engine Gremlin / Problem Solved !!
