Head Gasket Opinions ??
Old Dec 16, 2004 | 03:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well, what is being done with the thinner head gasket is to increase CR by reducing the fixed volume:
CR = (Vs + Vf) / Vf
Vs = swept volume
Vf = fixed volume, where cc of the heads is one part.
For a 350cid SBC each cylinder has 716cc swept volume. If the CR is 9.5:1 the fixed volume is:
Vf = 716 / 8.5 = 84cc
With a 58cc head there is then 26cc of "dead space" due to deck height, piston dishes, volume to compression ring and gasket compressed thickness.
While it is true that using a thinner gasket does not actually decrease change head volume it can be thought of as doing so. The thinner head gasket reduces fixed volume just as would the equivalent reduction in head volume.
Of course the benefit in enlarging the head volume while reducing gasket thickness and/or deck height is that the quench volume is reduced. This reduces octane sensitivity.
Old Dec 16, 2004 | 03:39 PM
88BlackZ-51's Avatar
88BlackZ-51
CR = (Vs + Vf) / Vf
Vs = swept volume
ahh! thanks jim! u always have a way of explaining things.....
Old Dec 16, 2004 | 04:18 PM
Roadster89's Avatar
Roadster89
Wow, Glad to see this thread had some educational use...
While I could not explain it as eliquently as 65Z01. I'm glad my assumption of recovery of cc's held true.
Doing the math for this...
For the original factory compression ratio of 10:1
9 = (716 + Vf) / Vf
Vf = 79.6
of which the cyl head chamber was 58cc's
leaving 21.6cc's for deck height and gasket
now that the head is 63 cc's, with a similar gasket
the Vf goes to 84.6, dropping the compression to 9.46:1
recovering almost 6 cc's with the .015 gasket...
the effective Vf is 78.6 resulting in a compression ratio of 10.11:1
Just what I wanted
If I may bring it back to my original question...
Does anyone feel there is a substantial risk to reliability, for a street driven, 10.1:1 compression (stock bottom end) 350 that will not see 6000 RPM, when using the .015 gasket?
Or should I just live with the half point loss in compression...
Anyone want to guess at the power loss ?
Old Dec 16, 2004 | 04:48 PM
Delta's Avatar
Delta
ok here is my guess at the power loss, it will be around Nil or even a slight negative power loss, you cleaned up the heads to flow better and give a better burn increasing power, you knocked compression down half a point slightly hurting power i will bet it will even out.
even if you lose a bit of HP from it, its nothing that cant be overcome with a supercharger or Nitrous.
anyway thats my guess, if i am wrong in my thinking, please guys correct me.
Old Dec 16, 2004 | 05:07 PM
65Z01's Avatar
65Z01
I think you should benefit from the added .1 CR due to less quench volume.
It won't give much CHP gain but should reduce ping tendency with a cleaner burn.
Old Dec 16, 2004 | 05:29 PM
Roadster89's Avatar
Roadster89
Delta: 65Z01: Thanks for both your replies, but I think you missed my point... all things being equal... a 9.46:1 engine and a 10.1:1 engine with all the same go fast goodies are going to make different HP. I wanted a guess as to that difference.
I know I'm going to come out ahead with the cam and head change over stock configuration (even with a drop in Comp ratio). But if the above suggests 25 CHP are lost due to the compression change... I'll take my chances with the thin gasket... for 5 CHP I wouldn't.
The .1 comp ratio over stock with the improved quench is a nice benefit, but I wasn't concerned about that HP gain... I think we agree the result should be less prone to knocking.
Old Dec 16, 2004 | 07:04 PM
CFI-EFI's Avatar
CFI-EFI
CR = (Vs + Vf) / Vf
Vs = swept volume
Vf = fixed volume, where cc of the heads is one part....
Great job.
9 = (716 + Vf) / Vf
Vf = 79.6
leaving 21.6cc's for deck height and gasket...
You understand this very well. I can't speak on the durability of the .015" gasket, but I am a STRONG advocate of a tight quench clearance. Failing any authoritative advice to the contrary on gasket life, I'd go with the thin gasket.
RACE ON!!!
Old Dec 16, 2004 | 07:37 PM
Roadster89's Avatar
Roadster89
CFI: Thanks for the encouragement...
I just read that the stock gasket was a .051 compressed (as Felpro 1044)... thats 11.2 cc's in area... the .015 compressed gasket (Felpro 1094) comes in at 3.2 cc's, so the resultant Vf drops to 76.6 cc's and the compression ratio would actually improve to 10.35:1... a rather significant .9 points of compression over the stock gasket with the 63cc heads.
One last thought on my understanding of the data that I'd like someone to confirm...
A stock .051 gasket's 11.2 cc volume would suggest that the remaining Vf after accounting for the 58cc cyl head volume is only 10.4 cc's, which needs to be divided among the piston contures, valve reliefs, and piston to deck height. This doen't suggest a whole lot of clearance room.... Seems to me the pistons come right to the top of the block
Old Dec 16, 2004 | 08:05 PM
CFI-EFI's Avatar
CFI-EFI
CFI: A stock .051 gasket's 11.2 cc volume would suggest that the remaining Vf after accounting for the 58cc cyl head volume is only 10.4 cc's, which needs to be divided among the piston contures, valve reliefs, and piston to deck height. This doen't suggest a whole lot of clearance room.... Seems to me the pistons come right to the top of the block
The remaining volume you come up with sounds about right. Typical L98 type sbc engines have about .025" deck clearance (flat of piston to deck). If you plan to use the thin gasket, you should check that on yours. The Chevrolet Power Book recommends .035" to .040" deck clearance, minimum. With a .025" deck and a .015" gasket, you'll end up at the high end of the minimum with .040". With your self imposed red line, of 6000 rpms, *I* think you'd be safe UNDER .035". The benefit of the quench area decreases as the distance increases. At about .060" there no benefit.
RACE ON!!!
Old Dec 17, 2004 | 10:08 AM
conv90's Avatar
conv90
About the .025" deck during a rebuilt:
This is a tipic value with STOCk piston and UNSHAVED block.
Many, many aftermarket pistons are available only with understroked compression height. (the distance from the axle of the wrist pin and the top flat surface of the piston). On a stock piston this value is a 1.560", but some aftermarket pistons are 1.540" (.020" LESS!)
So, the aforementioned value of 0.25" be now 0.045"!!
If you are not resurfacing the block an aftermarket piston set with the stock compression height is a good way to do not loose compression.
NOT always this data are available on all aftermarket piston sets.
Hope this helps
-Beppe-
Old Dec 17, 2004 | 10:13 AM
conv90's Avatar
conv90
.So the next question will be:
Which head gasket (for alum heads) with a thickness good to achieve the correct deck height (near .035" - .040") that promote the good effect of the squish?
Where to buy a .015"-.020" gasket good for alum gaskets?
-Beppe-
Old Dec 17, 2004 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
Hope this helps
-Beppe-
Beppe is absolutely correct. Most of the higher performance pistons maintain the factory deck height, but most aftermarket replacements are "decked" as Beppe says. The BEST way to handle this is to wait to deck the block until you trial fit them to the block and MEASURE the deck clearance.
The various on-line catalogs may not show the compression height of a piston, but the paper catalogs almost always have specs in the back of the book. This is part of engine building. Check the specs on EVERYTHING, and plan ahead.
RACE ON!!!
