Head Gasket Opinions ??
Old Dec 15, 2004 | 11:59 PM
Roadster89's Avatar
Roadster89
Default Head Gasket Opinions ??
I've slowly been putting together parts for a few performance upgrades, including a cam and new heads. After porting and milling the heads I ended up with a 63cc chamber, a few more than the stock 58cc's. I'd like to get some more of that back, without further milling the heads.
I became aware of a Felpro gasket that compresses to .015 vs. the usual .039-.041, this would lead to an almost 6 cc recovery. Seems to be just what the doctor ordered, but I'm not sure there isn't a catch.
Material longevity? Likelyhood of a bad seal to the block ?
Anybody with any thoughts or insight to share
Old Dec 16, 2004 | 09:30 AM
conv90's Avatar
conv90
You posted the same question I want to post...
I'm in the same boat...
Now I have a felpro 1010 (.039 compressed) with an added volume to combustion chamber of 8.9cc
Mr gasket part 1134 is a gasket of compressed 0.028 thick with 6,1 cc added volume compressed.
8.9-6.1 = 2,8cc .
I'm starting fom 62 cc so a near 3cc reduction should good for me.
The real problem is to use a gasket made for a iron block and an aluminum head.
I know that Felpro 1010 (.039 compressed) are good for this...
It seems also that Mr gasket part 1134 is good for aluminum heads...
Copper gaskets semms NO good to match an iron block to an aluminum head...
Some guru can chime in?
-Beppe-
Old Dec 16, 2004 | 11:46 AM
88BlackZ-51's Avatar
88BlackZ-51
8.9-6.1 = 2,8cc .
-Beppe-
i too would like info about this, i have the TFS 30400007 heads that are 62 CC, I was thinking of milling them down to 58CC and going with a thinner gasket, or leaving the 62CC and going with a thinner gasket?
it's a toss up....
Old Dec 16, 2004 | 11:48 AM
88BlackZ-51
8.9-6.1 = 2,8cc .
-Beppe-
what heads do u have? and do u have any other pics of those fat tires of yours? and what rims are they on? and do they fit well?
Old Dec 16, 2004 | 11:51 AM
NUckINg FuTS's Avatar
NUckINg FuTS
I will be using a pair of Victor Reinz Nitroseal gaskets #5746 when my new engine comes together. They have a .029 compressed thickness and are made for iron blocks using alum. heads. Same gaskets Lingenfelter uses on their SBC engines. Any Napa store should carry them.
Old Dec 16, 2004 | 11:52 AM
88BlackZ-51
Originally Posted by NUckINg FuTS
I will be using a pair of Victor Reinz Nitroseal gaskets when my new engine comes together. They have a .029 compressed thickness and are made for iron blocks using alum. heads. Same gaskets Lingenfelter uses on their SBC engines.
have a link to these? and since my heads are 62CC, what would this drop me down to with the .029 over the stock .051 i think it is.....
Old Dec 16, 2004 | 12:07 PM
conv90's Avatar
conv90
it's a toss up....
I'm planning to use ......
....... TFS 30400007 heads too!
I think that to do a GOOD milling you should disassemble the head, perform the milling with the appropriate machine, and then CLEAN it perfectly, and then reassemble .
If I was buying the CNC version with 64 cc, the milling of the heads is a must...
I prefer to buy the ready to install 62cc NO CNC chambers and the thinner gaskets.
I will go with thinner gaskets to gain 3 or 4 cc .
The right thikness with a bore of 4.130-4.166 will be a .022"-.026" to correct the +4cc of the TrickFlow heads.
Old Dec 16, 2004 | 12:14 PM
88BlackZ-51
i am thinking of the 0.028 gaskets that were used on the iron head L-98's.....
mine heads come in tomorrow, can't wait to see them. our stock gasket is 0.051 correct? so using the 0.028 would knock it down 5 CC to 57CC, would that be correct?
Old Dec 16, 2004 | 12:22 PM
conv90's Avatar
conv90
Yes you are correct, but NOW i'm using with stock heads a compressed gaskets thickness of .039" (Felpro 1010). These head gaskets are the ones GOOD to be used with IRON block and ALUM heads...
..So the .028" ones you are refferring (IRON HEADS) I don't think are the correct ones to use with ALUM heads.
Mister Gasket /Accel #1134 I think are the correct (0.028 multilayer).
If only TJwong can chime in...
-Beppe-
Old Dec 16, 2004 | 12:25 PM
ralph's Avatar
ralph
I've studied this quite a bit in the past as i had the same issue you guys are having. Things may have changed since, but at the time, the .015 felpro was not recommended for alumin heads where the compression ratio would be over 10:1. Chevy made a .029 gasket that was compatible, but the edge of the gasket protruded into the combustion chamber between the cylinders and it failed after a few seasons. TPIS resells a .029 gasket as well, but i dont know who the mfr is. I know people that are using them without any problems. The Victor nitroseal is a good gasket (which i used on my 350 after blowing the GM gasket). I thought the compressed thickness was .026, but my memory aint great. If you want to spend the $, Cometic will make you a custom made stainless viton coated gasket (min thickness is around .025 tho). These are a completely different construction than the other gaskets mentioned so far as they are multi layer stainless throughout, compatible with alum and can handle crazy compression. Flatout makes coated copper gaskets that go as low as .020, but i have no experience with them. When i was researching this, it was recommended NOT to use copper on a street car (concerns over coolant leaks), but these are a new design with a coating that is supposed to stay sealed??? good luck
Old Dec 16, 2004 | 12:56 PM
conv90's Avatar
conv90
Thanks Ralph,
The Mr.Gasket I was referring are:
Top-quality head gaskets for today's performance engines.
Head Gasket, Composite Type, 4.130 in. Bore, .028 in. Compressed Thickness, Chevy Small Block, Pair
Because of the technology available in today's high-performance engines, there came a demand for more durable head gaskets. Mr. Gasket responded to this challenge by creating the Ultra-Seal lineup. They feature excellent compressibility and high-temperature endurance, while not becoming brittle or brinelling aluminum cylinder heads. Their 5-layer composite construction sandwiches the patented Grafoil core material between two steel plates for strength, and a special elastomer coating is applied to both sides for leak-proof sealing protection. In addition, they're corrosion-resistant for compatibility with all types of fuel, and they won't require retorquing.
Vendor Mr. Gasket Co.
Product Line Mr. Gasket Ultra-Seal Head Gaskets
Bore (in) 4.130
Bore (mm) (Not Specified)
Gasket Material Steel core laminate
Compressed Thickness (in) .028
Compressed Volume (cc) 6.147
Lock Wire No
Quantity Sold as a pair.
Notes (Not Specified)
Old Dec 16, 2004 | 01:02 PM
scorp508's Avatar
scorp508
Don't forget to test for valve to piston clearance with the thinner gaskets and/or milled heads.
Old Dec 16, 2004 | 02:34 PM
CFI-EFI's Avatar
CFI-EFI
Sort of... Kind of... But not really. The cc's of the heads, is the cc's of the heads, ONLY. The gasket volume gets added in when you do the calculation for the compression ratio. Adding less cc's makes a difference, but a 62 cc head, is still a 62 cc head.
RACE ON!!!
Old Dec 16, 2004 | 02:38 PM
88BlackZ-51
RACE ON!!!
maybe i am missing something, with my TFS, they are 62CC, so if i went to a thinner gasket, would not bring the CC down to 58 or so?
Old Dec 16, 2004 | 02:57 PM
CFI-EFI's Avatar
CFI-EFI
What you are missing, is reading the post you quoted. The HEADS are 62 cc's. If you use them with .051" gaskets the HEADS are 62 cc's. If you use them with a .028" gaskets then the HEADS are 62 cc's. If you use them with .019" gaskets the HEADS are 62 cc's. Since the cc's of the HEADS is the cc's of the HEADS ONLY, you can't change the cc's of the HEADS by changing the gaskets.
RACE ON!!!
Old Dec 16, 2004 | 03:02 PM
88BlackZ-51
RACE ON!!!
i am talking about CC recovery......i do know that a 62 CC head is a 62 CC head.......listen, i am learning one day at a time CFI-EFI!!! Relax!!
the heads i bought are 62CC, i want to bump it down to 58CC to keep my CR, what size gasket will do this for me? maybe that is a better question.
Old Dec 16, 2004 | 03:14 PM
scorp508's Avatar
scorp508
No, gaskets change the overall setup which is made up of....
Bore
Stroke
Connecting Rod Length
Cylinder Head Volume
Deck Height
Head Gasket Bore
Head Gasket Thickness
Piston to Cylinder Wall Clearance
Top Ring Land Height
Piston Dome Volume
...and used to calcuate compression ratio.
To Head Gasket Opinions ??
Old Dec 16, 2004 | 03:16 PM
scorp508's Avatar
scorp508
You can't do what you are articulating, this is what he means. Your heads are going to stay 62cc. This means you want to remove 4cc from the rest of your setup, not the heads.
Take your original gasket bore and thickness, calculate the volume. Then find a gasket that is 4cc less.
Old Dec 16, 2004 | 03:17 PM
88BlackZ-51
Bore
Stroke
Deck Height
Head Gasket Bore
Piston Dome Volume
that sounds even more confusing to me......great!!
what is the stock thickness of a 1988 gasket? all being equal, if i was too take off my 113's and put on the TFS with the 62CC, should i go with a thinner gasket? and if so what would that change?
Old Dec 16, 2004 | 03:18 PM
88BlackZ-51
thanks! any recommendations?
yah, i am dumb!
