I have just finished polishing my Plenum and Fuel Rails and now was just about to start on the Runners. I was wondering what tools are required to sand down the Runners, is there some special bit I should use on the end of my drill? I have started hand sanding them but cant seem to remove all the casting marks. If anyone has done this and could give me some tips that would be great.
I use those sanding wheels they look like flappers,I use them on a air cut off tool with different sizes and grits.They have worked great for me and I have done around 5 or so TPIs.I knock the cast down with that and then finish with hand sanding and then polish to a mirror shine.
I used a power drill with a circular wire attachment, on the plenum, runners, alternator bracket, etc.
I polished it off with Mothers Alum polish.
Pics are in my profile.
While we're discussing the issue of polishing aluminum, I've taken the time to polish a few of my suspension pieces to a mirror like finish with the help of Mother's Aluminum Polish. This stuff works great, however I hope someone can reassure me that the aluminum suspension pieces weren't coated with some kind of protective coating(?). I've meant to ask this for a while due to the fact that wheels have a clear coating on them which protects them. I'm hoping this doesn't apply to suspension pieces. If so, I might be coughing up some extra dough for new ones.
I believe that when using Mothers Alum Polish, the rag [applicator] turns black while you rub it on.
Now, if the aluminum has a coating, the rag will not turn black, that's how you can tell if its coated.
Flapper wheels are good;the softer scothbrite pads on a die grinder work well in taking down rough cast. Have you tried a sisal wheel? Those are also helpful. There's a company called TarHeel parts that will actually tell you what you need and their prices are very reasonable, as it's too easy to waste money on stuff you may not use. Ask me, I've got boxes of 'experimental stuff. Sorry, no link as I'm an internet moron.
I think you will find a steel brush on a bench grinder is a good start... also, a dremel will be real helpful.
when you are done, protect the finish, there are a couple of things out there... one called Zoop Seal, and another called "Snake Skin" (I think).
I've heard that Zoop Seal is a good product from a couple of people. You have to make sure that what you are going to seal better be the way you like it because you can't repolish it once it's sealed.
I'm not sure if there's a remover or not. I also saw this advertized and used on Trucks! tv. $120. or so for enough to do 4 wheels.
Oh yeah, I get tons of the black residue when polishing up the suspension pieces. Thanks, that's one less thing I have to worry about.
No air or power tool is going to do a great job on the sanding the tubes because they leave flat spots. The plenum is a cake walk compared to the tubes. I haven't done alot of aluminum polishing, but enough to make it look good. I used strips of emery clothe to sand my tubes, using the shoe shine technique . That almost sounds like a real technique You can sand a good third of the surface area with each pass. Pulling the clothe on a slight angle and constantly moving up and down the tube will yield good results. Work your way down to 2500 wet and dry paper followed by a polish and you will be happy with the results. If you have a buffing wheel and compounds you can make it look like chrome. I was going to do mine but the dents in them and the crappy valve cover castings made me change my way of thinking. I went with paint and polished pieces. I love it
It took a little work, but those crappy valve covers can look like this:
Strick, every time I see those pics Im amazed. Awsome. Had to be more than "a little" work!
Black Vette, The covers are magnesium, the coating is not just paint, its alluminum coating. Paint stripper wont disolve it.
I removed the paint with glass beads. This revealed some of the casting flaws which, I think, GM decided paint over with the textured paint. I then started with 500 grit and worked my way up to 1500 and then used a buffing wheel on a drill with some compound and finally Mother's Mag and Aluminum polish. There are still some areas that have a flaw or two, but the over all look is really an improvement.
its really not hard to polish aluminum. sheet and bar stock are a piecs of cake. cast takes time to get all the roughness out. scotchbrite pads for the 4" grinder work great with out leaving gouges.
Ive polished alot of aluminum over the years & the bottom line is that it is alot of work but the end result is worth it...anyway, heres a link to one of the places I get alot of my compounds & wheels....The kits will get you started....Buffing & Polishing
Heres a tutorial on the same site which is very helpful for the newbie: Tutorial
another tut for wheels wheel polishing tutorial
