'85 digital dash question
Old Dec 18, 2004 | 10:23 AM
LangstC4's Avatar
LangstC4
Default '85 digital dash question
I guess is is my turn to have a digital dash problem ...but have not seen this specific one discussed (at least it didnt show up in my searches). Now that it gets dark earlier, it is very noticable.
When I am driving...the dash will randomly go dark. It does not seem to be related to bumps or turning or any mechanical change in the car...it just goes dark. Then after a few minutes it will just as randomly come back on. The high beam and turn indicators dont act up....it is like a switch gets turned off and then back on. I have a dash cluster repair book and a have read about ground problems etc...but they refer to the high beam indicators as a sign of the problem... but I dont see that. Also ...when I stop the car and restart the dash resets and works normally until the next time it goes dark. It happens a least once per hour of driving and mainly after the car reaches operating temp...never when it is cold. Any thoughts?
Old Dec 18, 2004 | 10:35 AM
_twisted_'s Avatar
_twisted_
It sounds like a thermal problem, as I to am have this along with the other documented cluster issues in my 86. It could be a cold solder joint on a pin connector, dirty connection(s) or one of the boards.
Stay tuned, I am going to attempt to do a vid clip tutorial of a cluster repair over the hoildays. I am confident I can fix it, as long as I dont need any parts, on my kitchen table. So long as my 4yr old doesn't try to solder I should be ok with the only thing remaining is to make a good ground back at the car.
At the same time I will be testing a "new" product for cleaning and preserving electrical contacts and reostats, I may even do the Blose if time permits.
Back to the cluster, I am expecting the 882's w sockets to arrive on the 23rd and expect to do the repair on the 27th.
Old Dec 18, 2004 | 10:41 AM
LangstC4's Avatar
LangstC4
Thanks...I will stay tuned for your update.
Old Dec 18, 2004 | 10:51 AM
mikey whipreck's Avatar
mikey whipreck
Sorta sounds like the onboard power supply in your cluster might be on it's last legs...
If that's the case soldering won't really help much. But you could always try to take it apart and clean and fix the solder joints, it won't hurt.
Old Dec 18, 2004 | 10:58 AM
LangstC4's Avatar
LangstC4
I forgot to mention that the guages and readings are all still working during the dark spells...in the daylight I can still see them faintly in the cabin light...but no illumination. Kinda rough going at night though.
Old Dec 18, 2004 | 12:12 PM
_twisted_'s Avatar
_twisted_
Any source for parts?
Old Dec 18, 2004 | 12:35 PM
mikey whipreck
In that case there is a photo-light sensor in the top left of the dash cluster. This might be burnt out. There is a way to bypass that, and it has been done before. Do a search and you'll find the answer with pictures to aid you...
www.batee.com is an excellent resource by the way
Old Dec 18, 2004 | 12:36 PM
mikey whipreck
If you could find another cluster (i.e. junkyard) and steal the power supply out of that, it may work... I wasn't able to do this myself, and I had to have my cluster rebuilt...
Old Dec 18, 2004 | 01:16 PM
jfb's Avatar
jfb
There are two circuit boards in your cluster and they plug together with a single row of connectors. The pin closest to the center of the circuit board carries the lamp current and the socket on the rear board has an age relaxed spring and now has connection resistance. The lamp current passing through this connection resistance makes so much heat that it has unsoldered the pin on the front board and it makes intermittent connection causing your 4 lamps to go on and off randomly. Resoldering the pin will not fix this problem and replacing the socket is difficult. I soldered a short piece of insulated #22 hookup wire from the pin to the socket and I will never have that problem again.
Old Dec 18, 2004 | 06:44 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
My 84 had somewhat of a similar problem, i resoldered all the connections and didn't really help. Soldered a extra ground wire onto top pcb and ran out to engine ground, the one on top in the front, and display is now very steady.
Old Dec 18, 2004 | 09:04 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I agree, it sounds like your light sensor may be the cause.
This is behind the little square hole on the top left.
Old Dec 19, 2004 | 09:19 AM
rick lambert's Avatar
rick lambert
Haven't checked the "search" for a long time, but if you can find thread #885976, it has an excellent color picture of how and where to add an additional wire for ground in the circuit board. The rebuilders all seem to piggy back ground wires in their repairs. If you can't find it-just email me, don't know how to email it, but I can certainly fax it to you if you need it. Good luck.
Old Dec 19, 2004 | 01:16 PM
LangstC4's Avatar
LangstC4
I saw some PIX on a site referenced above "www.batee.com" that showed a jumper wire soldered into the bottom left hand corner of the PCB. I tried searching for the referenced thread number... but no luck I did find a bunch of bulb replacement and ground check threads...(seems to be some major opinions on the 194 vs 882 bulbs).
The defective photo sensor idea seems promising (when I hold my finger over it...it dims out slowly to the same level, and the problem is probably temp related (as the car is warm when this happens)...but I cant find anything written on bypassing the sensor. The book I have speaks of grounding the ambient temp sensor near the firewall somewhere...but I have not found it yet (maybe not an '85 part).
The dash dimmed out twice yesterday coming and going from a sunny run to Capitola...ran great this morning in the 40 degree fog. As much As I hate the idea ...I think the dash is coming out over the holidays. Thanks for all of the help and suggestions.
Old Dec 19, 2004 | 09:50 PM
mikey whipreck
I )...but I cant find anything written on bypassing the sensor.
Lemme find you the pic you need...
EDIT::::
here we go
Okay now the explanation:
see that little circle in the bottom right of the pic? That's your photo cell. What that wire is doing is bypassing the photo cell, so your cluster WILL NOT dim. There is not further instructions needed. If you just solder a small wire exactly like that, that's all there is to it. If it works, you found your problem. You should be fine just leaving it go if it works. If you experience the same problem, the wire is simple to remove.
Oh- BTW, you're '85 DOES have the ambient temp sensor. But the problems you describe do not point to that ground as being a problem. If you would like to see where that sensor is, lower your drivers side lower dash panel, and in the front at the firewall you will see the interior side of the Ambient temp sensor....
Old Dec 20, 2004 | 09:22 AM
LangstC4's Avatar
LangstC4
Thanks for posting...that is a great picture .... To defer pulling the dash out..I spent some time in the engine compartment and under the car or looking for loose or missing bell housing grounds etc (per my dash repair book)...and couldnt find anything looking particularly wrong...actually, couldnt find much of anything period cuz it is so tight in there (no black and white striped wires to be seen). Hopefully it is not particularly ground related.
The former owner told me about a dash problem that he "fixed" right before selling me the car...(and gave me his dash repair book for reference). My guess is that it probably is the same intermittent problem. Thanks again for all the help...Happy Holidays!
To '85 digital dash question
