What is this Bosch box?
Old Dec 18, 2004 | 11:50 AM
357L98's Avatar
357L98
Default What is this Bosch box?
Behind the passenger side dash pad in my 85? Anybody know?
Old Dec 18, 2004 | 12:39 PM
mikey whipreck's Avatar
mikey whipreck
I was always told the amp for the Bose radio is there...
On an '85, there are two other things I think it could be. First is the ECM, second there is a special MAF Burnoff Relay (85 only) which is also in that area...
Old Dec 18, 2004 | 12:48 PM
bogus's Avatar
bogus
I vote ECM... could be a bosch reman. More details?
size... colour... things like that. Box is so vague.
The early bose systems didn't have stand alone amps.
Old Dec 18, 2004 | 12:52 PM
357L98's Avatar
357L98
Its a small silver box, about 2x4 inches or so. If you remove the passenger side bread box, you're looking directly at it. Its mounted vertically to the plastic dash structure. I'm sure its definitely not the ecm, based on its shape. Just wondering what it does, and could I remove it.
Old Dec 18, 2004 | 12:58 PM
MrRenoman's Avatar
MrRenoman
I think you're looking at the MAF burnoff module/relay. It's mounted directly behind the breadbox. I wouldn't remove it. It's an integral part of the MAF. I know the '86 and later models didn't use the burnoff module so there may be a way of removing it if the circuit is rewired to mirror the later models. Don't know if this can be done, never tried it or researched it much. I'm sure you could move it, seems there's a long pigtail from the harness to the module.
Old Dec 18, 2004 | 01:15 PM
357L98's Avatar
357L98
That sounds like a good possibility, since the car has a Bosch MAF on it. I will surely leave it alone if that's what it is. I have no desire to rewire the car, I just wanted to get rid of it if it was not doing anything.
Old Dec 18, 2004 | 01:31 PM
Muffin's Avatar
Muffin
MAF burnoff module,guarenteed.
Old Dec 18, 2004 | 01:48 PM
85blkrose's Avatar
85blkrose
thats exactly what it is the burn off relay. the ecu drops down from the hush panel from the dash pad down.
Old Dec 18, 2004 | 01:53 PM
357L98's Avatar
357L98
Thanks guys! That's just what I wanted to know. Its going to stay right where it is.
To What is this Bosch box?
