Vacuum line locations for 85?
Old Dec 19, 2004 | 04:58 PM
DarthD's Avatar
DarthD
Default Vacuum line locations for 85?
I have a few vacuum lines that I can't find where to connect. Is there a good diagram somewhere?
Old Dec 19, 2004 | 05:15 PM
Wayne88's Avatar
Wayne88
I think this diagram will cover an '85.
Old Dec 19, 2004 | 05:19 PM
DarthD's Avatar
DarthD
Thanks! The EGR soloniod is in the wrong place but maybe the lines are still the same. I'll check it out.
Old Dec 19, 2004 | 07:42 PM
SupaVette's Avatar
SupaVette
no, that diagram is diffrent to the 85, i think it's for 86. the 85 has a t-piece under the throttle body, which goes to fpr etc and the pipe from the purge solenoid goes onto the pipe by the pcv valve. thats just a quick look, if you tell me where the pipe is now, and how big it is i can maybe tell u off memory
Old Dec 20, 2004 | 02:31 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
This is for the 85. It should be stuck on your radiator.
To Vacuum line locations for 85?
