New floor jack?
Old Dec 19, 2004 | 05:54 PM
bheston's Avatar
bheston
Default New floor jack?
As we all know, it's a bit of a challenge to get the front of the Corvette up in the air. I have a Lincoln floor jack (USA version ) and it works (fron the side) but not without touching the rockers a little.
I've been looking at those cheap aluminum jacks Harbor Freight has been pushing. They look neat and just may be the answer if the saddle height is low enough. Does any one have the cheap aluminum or perhaps the expensive aluminum jack and has had good success with stuffing under your C4?
Old Dec 19, 2004 | 06:07 PM
dwestsr's Avatar
dwestsr
One trick I've learned is to drive the car onto a 2x6board under each of the front wheels to give the needed clearance for my jack. That way almost any kind of floor jack will do.
Old Dec 19, 2004 | 06:53 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I've seen those Harbor Freight jacks and you know the old saying, "You get what you pay for"?
Well, it's true, I've seen two of those jascks up close and they don't compare to my Crafstman jack and NAPA even sells one.
The NAPA jack was around $100-140 and the Craftsman cost me $200(but I got a few discounts and the final cost was around $175).
Here's the 1.5 ton(I bought the 2 ton)
http://www.sears.com/sr/javasr/produ...id=00950240000
I couldn't find the 2 ton one on line.
Old Dec 19, 2004 | 06:58 PM
bogus's Avatar
bogus
I have an AC Hydraulic jack. Made in Denmark. It's is SERIOUS.
I have the DK13HLQ. It is low, low, low... and will reach under the front to lift the car from the k-beam.
This link is from their UK subsidary - http://www.ac-hydraulic.com/division_uk.htm
It ain't cheap... but the best damned jack I have ever used.
Old Dec 19, 2004 | 08:03 PM
vms4evr's Avatar
vms4evr
I have one from HF. It is the Aluminum racing jack. 3000lbs lift. Handy for autocrossing since it is fairly light, about 35lbs. I can get it under my C4 from any angle. The saddle height is low enough. I got the $150 one. So far after a year I have no complaints and it doesn't appear to be junk. I use it at home all the time.
Granted they do sell a lot of cheap stuff that is questionable quality. For example they have a $20 1/2 drive torque wrench. On sale for $10 now. Great for tightening the lug nuts up when I swap wheels around at home or autox. Probably have to replace it after a couple of years. But the very high quality ones at Sears are 3-10 times the cost. The rest of my tools are all Craftsman so I'm not a cheapskate all the time
Graham
Old Dec 19, 2004 | 09:21 PM
bheston's Avatar
bheston
I was watching American Hotrod and I noticed Boyd's guys using a nice aluminum jack. I paused the show (thank you Tivo) and wrote down the name "Litening". I did a search and those things are pricy :
http://www.performancebodies.com/200...cks/jacks.html
Does anyone know anything about them? I'd be willing to invest in one IF I knew it would slide under the Corvette easier than my Lincoln. On the other hand, the 2x6 suggestion sounds much cheaper.
Old Dec 19, 2004 | 10:46 PM
SPEED750's Avatar
SPEED750
My local walmart just started carrying aluminum floorjacks. The look cool and at $75 it's one of the most expensive tools they carry. I'm not saying its any good, but you might want to take a look. :o
Old Dec 19, 2004 | 11:38 PM
comp's Avatar
comp
looks Nice
Old Dec 20, 2004 | 12:17 AM
Grace91's Avatar
Grace91
Old Dec 20, 2004 | 01:46 AM
bogus's Avatar
bogus
Originally Posted by comp
looks Nice
It is the best jack, ever.
the down height is 3.5", max lift, 31".
It is heavy and expensive, no question, but it is well worth it.
I bought the jack and 2 stands for $800.00.
Old Dec 20, 2004 | 12:06 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I have one of those aluminum racing jacks from harbor freight and I like it so far. I also had problems with contacting just the frame rails and nor the fiberglass lip, so I fashioned a sort of saddle out of C-channel for the fraame rail to set in. The C-channel now makes contact with the jack saddle, and it seems to work well.
I'd post pics if I knew how.
Old Dec 20, 2004 | 12:44 PM
HC96LT4's Avatar
HC96LT4
Got the 2 ton Sears jack for $160 out the door. I love it!!!
Exept that it doesnt come with the foam sleeve like the 1.5 ton!!!
Old Dec 20, 2004 | 09:29 PM
93ZF6's Avatar
93ZF6
I use the 2x6 trick and can easily get my Lincoln Jack under the rocker, The old man told me of a buddy trapped under a car for seveal hours due to a cement block used as a jack stand collapsing. I figure one cheap jack or jack stand can ruin your weekend or worse.
Old Dec 20, 2004 | 10:12 PM
rws.1's Avatar
rws.1
Crewline Low profile Aluminum Racing jack 2tons, weighs 45 pounds. minimum clearance 3-3/8 inches ..... $119 at Sam's Club !
Old Dec 20, 2004 | 10:17 PM
BamaVette87's Avatar
BamaVette87
I have a 3.5 ton Arcan "UltraLow" floor jack that I bought at Costco for less than $90. The saddle sits at 3" and lifts to 21". It seems to be extremely sturdy and very well constructed.
(Pretty car, RWS!)
Old Dec 21, 2004 | 09:13 AM
shotchkiss's Avatar
shotchkiss
Got the 2 ton aluminum jack form Sears, slides right under the nose of the car no problem, even without boards, just pushes the spoiler up a little. Rockers clear fine. Handles on it make it real easy to move around under the car, and it's light enough to carry between my garages. Best jack I've ever used, got it on sale for $128 after multiple discounts.
Old Dec 21, 2004 | 10:02 AM
c4cruiser's Avatar
c4cruiser
Costco sells an Alltrade aluminum jack for $119 which is apparently the same version as the red/silver one that Shuck's (Kragen) carries. 2 ton capacity and about 45lbs weight with a 2-piece handle. The Shuck's jack was on sale last week for $99.
The small HF aluminum jack would be great for taking to autocross or track days, but it only has a 15" lift which is OK for tire changing. Their larger jack also has a 3000lb capacity but you get 2 extra inches in lift. HF always has sales going so the larger jack for $99 would be a good deal if the 3000lb capacity is enough.
To New floor jack?
Old Dec 21, 2004 | 10:16 AM
HammerDown's Avatar
HammerDown
I looked at the Craftsman and HF aluminum racing jacks and they look exactly the same to me. Seems like I read on another forum that they are all made by the same company.
Old Dec 21, 2004 | 11:19 AM
Wheelman's Avatar
Wheelman
http://www.harborfreightusa.com/usa/...do?itemid=2672
I got the aluminum racing jack from HF as well, just bought it the other day and am very impressed, it is by no means a piece of crap, much better than the smaller sears jack i have been using for years, and much lighter too
Old Dec 21, 2004 | 11:54 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I bought this Michelin one at Sams Wholesale ( basically wal-mart wholesale) for under $70. It's not aluminum and it's about as heavy duty as they come (3-1/2 ton) It's the same one used in Michelin tire stores. I cant believe it was so cheap. I was in there yesterday and they still had some.
