Water bypass for throttle body
Old Dec 20, 2004 | 02:46 PM
RED LT4's Avatar
RED LT4
Default Water bypass for throttle body
I have seen a post about the bypass and was wondering what was the best way to do it? There was a post about blocking off the water hoses, can some one tell me what hoses and where?
Old Dec 20, 2004 | 02:52 PM
FELNGR8's Avatar
FELNGR8
Read through this post. The replies to my question indicate alternate ways to bypass the TB other than to join the two hoses that attach to the TB itself.
http://forums.corvetteforum.com/showthread.php?t=966123
Old Dec 20, 2004 | 02:59 PM
RED LT4's Avatar
RED LT4
Yes I saw that and do thank you. I have a LT4 motor and the bypass looks a little different. Do you block it at where the hose ties into the radiator? Help......
Old Dec 20, 2004 | 03:31 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
the design of the routing send hot coolant through the TB for cold weather applications. if you trace the hose, you can get a single hose that will attach the two ends and not have to worry about a splice. Or a forum member has an add in the marketplace as a "one time sale" that has polished pieces that just look briliant!!!
Old Dec 20, 2004 | 03:56 PM
96GS#007's Avatar
96GS#007
- Disconnect the hose from the driver's side of the throttle body.
- Disconnect the small hose between the passenger side of the throttle body and the hard line that runs along the passenger side valve cover.
- Connect the hose you just disconnected from the driver's side of the throttle body to the hard line.
You're done.
Old Dec 20, 2004 | 04:05 PM
RED LT4's Avatar
RED LT4
This may not be true but I read a post that the lines could be removed. Now is that from a different year C-4 or something? Is it best just to bypass the TB like you said? Thanks
Old Dec 20, 2004 | 04:08 PM
kwik_ta's Avatar
kwik_ta
You're done.
yeah what he said. that was a simple way of explaining what i was saying above. Thanks Jim!!!
Old Dec 20, 2004 | 04:51 PM
FELNGR8's Avatar
FELNGR8
The water goes in to the TB on the driver side, and comes out on the passenger side. You just pull the hoses off the sides of the Throttle Body and join them, letting the joint lie hidden under the TB.
Over the years there have been various size hoses, and the two sides are different sizes. Mine is 1/2" in and 5/8" out. That is where the problem comes in. The kit they all sell is just a "hose splice" packaged with two hose clamps, but smaller than what I needed. For the earlier cars that match the packaged kit it is much less hassle.
I had to go to a hardware store to get the correct size splice, then it was shorter than the one in the kit, so I had to replace the 5/8" hose to stretch it to meet the 1/2" hose.
This is a lot of hassle for a simple fix. Some suggest new hoses to get rid of the joints altogether, and to look neater. You have to know the size and lengths of the hoses "you have" on "your car". To get them off to measure and what not you have to dump a lot of coolant.
Have a garage and don't mind downtime?
Old Dec 20, 2004 | 08:55 PM
Perfusion's Avatar
Perfusion
You're done.
Exactly what I did on my LT4...and it was a good thing the hose was long enough, as I had *zero* luck finding connectors at my local hardware store!
Old Dec 20, 2004 | 10:54 PM
96GS#007's Avatar
96GS#007
I have an LT4 like you (see my sig) and I did mine nearly 7 years ago. My advice is accurate.
Old Dec 21, 2004 | 10:00 AM
Strick's Avatar
Strick
My 92 is probably a little different from your 96, but this is how I did it. I have a "T" that comes off the top radiator hose. The smaller hose that comes off the "T" goes to the TB. I think this hose is 5/8" I bought a longer piece of that hose and covered it with S/S braiding and ran it across the top of the radiator (after rotating the "T") and down to meet the hose that was on the other side of the TB, which I think is 1/2". I used the kit (yes too much $$ for what you get) which had the coupler for joining 1/2" and 5/8" hoses. This picture will show the routing across the top of the radiator.
This picture shows the connection of the 2 hoses:
I finished this off with rubber plugs that cover the TB nipples.
Old Dec 21, 2004 | 10:17 AM
RED LT4's Avatar
RED LT4
I may be makng a simple job diffucult.....but is there any way the line not used can be removed? Just to make it cleaner and neater?
Old Dec 21, 2004 | 10:38 AM
rjetrider's Avatar
rjetrider
I have a 94 and I went to the local autoparts and found the right hoses to completely eliminate all of the factory stuff(metal T's and hosing). If you just get rid of the throttle body hose by plugging up where it comes from you could run into problems, because the plugs have been known to crack or pop off(even when correctly clamped)
Old Dec 21, 2004 | 11:58 AM
96GS#007's Avatar
96GS#007
You must use the line. It is part of the cooling loop for the cylinder heads.
Old Dec 21, 2004 | 12:09 PM
RED LT4's Avatar
RED LT4
OK ............It will be done. Thanks for the info. I will keep the loop intact
Old Dec 21, 2004 | 04:41 PM
MikeC4's Avatar
MikeC4
You're done.
I just bypassed my '95 LT1, and Jim is right on...(but he already knows that)! The only additional thing I did was to put 1/2" rubber bypass caps on the TB inlet and outlet tubes to keep out any crud and to make it look nice.I got these 2 caps at Pep Boys for $1.99... Thanks Jim!
Old Dec 22, 2004 | 10:04 PM
DRE69L46's Avatar
DRE69L46
Default Any reason not to do it?
I'm sure GM had a good reason for spending the $ to route the hot coolant through the TB. I assume it's to prevent icing in the TB venturi. (I'm a pilot, and most small airplanes use exhaust to heat the carburetor to prevent TB icing. It can occur over a wide range of temperatures and relative humidity, but it's most typical during cool and/or humid weather.)
So, those who have disconnected the lines from the TB, any adverse effects?
Thanks.
To Water bypass for throttle body
Old Dec 22, 2004 | 10:15 PM
BowTieBlood's Avatar
BowTieBlood
Sorry, I assume it's been answered with numerous replies as these guys are always on top of everything, but I'll go ahead and post real quick without reading...
Remove the hose completely that connects passenger side of tb to piping.
Remove end nearest tb of hose on driver's side, and install to piping where previous hose was placed.
Done.
Old Dec 23, 2004 | 08:50 AM
96GS#007's Avatar
96GS#007
Thanks.
I believe you're right, it's there for the reasons you mentioned.
I've driven mine in temps that ranged from below 0* and little humidity to 100*+ and 90% humidity, to just about everything in between...i.e. where the problem can actually occur like you stated I've never had a problem nor am I aware of anyone having a problem.
I think this is one of those things that end up on a car to correct an issue that "one half of 1%" may actually see. Remember, the basic tb architecture has been in use since 1985 on everything from Vettes and F-Bodies, to Impala SSs, to taxi's, to police cars.
Old Dec 23, 2004 | 08:59 AM
LT4BUD's Avatar
LT4BUD
You're done.
That is how I did my LT4.....
