...most small airplanes use exhaust to heat the carburetor to prevent TB icing....So, those who have disconnected the lines from the TB, any adverse effects?
The key point here is carbs, wet intake with evaporation that will cool things down. Our C4s are fuel injected at the intake valve. There's no wet gas landing on the TB and evaporating, cooling the TB below the ambiant temp and condensing H2O vapor and freezing the TB.
I flew jets and didn't have to worry about carb heat or mags. But at 10 degrees C or 50 degrees F or lower, when visable moisture is present, you can make ice in the intake portion of the engine the same way our TBs can. The only difference is the TB is also warmed by the operation of the engine. Our jets have to take hot air and route it into the intake of the engine to reduce ice build up. So, if you live in a climate that gets cold (below 32 degrees) and has high humidity (fog, mist, rain ,etc) without the coolant running through the TB, you could have a little icing problem in the TB. I don't really run my Vette in those kind of conditions so I bypassed my TB.
Is there any one here from mid-state Maryland who has done the TB bypass and driven in winter?
One year the icing line for every storm was almost exactly along I-95 between Washington and Baltimore. Ice at I-95, snow north or NW, rain to the south or east.
This is a key point for the C4, which rarely goes airborne. The underhood warming from the engine should be sufficient for de-icing the TB. If icing does occur, and the venturies are stuck, let the car idle for 5 or 10 minutes which should be enough time for heat transfer from Intake/Block to TB to de-ice. I may be full of , but one thing C4's and all vette's have in common, is plenty of warmth under the hood!!
