Trickflow's
Old Dec 20, 2004 | 03:39 PM
88BlackZ-51's Avatar
88BlackZ-51
Default Got my Trickflow's today.....
Just got my TFS heads, They look pretty good! I decided to get the TFS-30400007 heads.
Umm, I have the 1.6 self aligning LT-4 GM RR's. What else do u recommend with this install? All I have so far are the RR's.
Thanks!!
And these will be going on a 350 with stock bottom end, Do u recommend porting them, or are they suffice out of the box if they were to go on a SR/219.
Old Dec 20, 2004 | 03:54 PM
Red Tornado's Avatar
Red Tornado
porting them further is going to cost a small bundle, are you racing for $$? you'll need to have them milled to reduce the chamber size by 4-8cc's. if they have hardened guideplates, you'll want to remove them since you're going with self-aligning RR's.
Old Dec 20, 2004 | 04:27 PM
88BlackZ-51
dont see any hardened guideplates brad......so anything else beside's milling them down, or should i go with a thinner gasket, and no i am not racing for money, haha!
Old Dec 20, 2004 | 05:02 PM
ralph's Avatar
ralph
Are those heads setup for .560 lift? I know that became an $ option for the AFRs.
Old Dec 20, 2004 | 05:15 PM
88BlackZ-51
yeah, they are good till .600, i got the dual 1.46 springs ralph.
Old Dec 20, 2004 | 07:24 PM
ralph's Avatar
ralph
Good.....just check'n
Old Dec 20, 2004 | 07:38 PM
Red Tornado
ok, go with .039" (compressed) head gaskets, these should run about $80 for the pair. you'll want a nice tight quench
Old Dec 20, 2004 | 08:12 PM
LD85's Avatar
LD85
Do you have the stock deck height, how much is "in the hole"?
Add that too the Head gasket for your quench dim.
Old Dec 20, 2004 | 08:29 PM
ralph's Avatar
ralph
most stock bottoms put the piston .025 down the hole
Old Dec 20, 2004 | 08:59 PM
CFI-EFI's Avatar
CFI-EFI
The tighter the quench (piston to head clearance) the more effective it is. My Chevrolet Power Book recommends .035"-.040" minimum clearance. The benefit gradually decreases as the clearance increases. Once the quench reaches or exceeds .060" the benefits are gone. A stock .025" (or more) deck clearance plus a .037" gasket (= .067") will provide no advantage from quench.
RACE ON!!!
Old Dec 20, 2004 | 10:41 PM
Pete K's Avatar
Pete K
I will be picking up a 383 short block tomorrow and my builder recommends (for me) an .025 compressed head gasket. I don't have the brand or part number yet but will post it tomorrow if you are interested. I saw it and it is white! I think it is a cometic but not sure. I have been a diehard fel-pro guy, but he says this is the ticket. We'll see.
Old Dec 20, 2004 | 11:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You mentioned the TFS have 7/16" rocker studs, are the GM RRs for 3/8" or 7/16" studs??
Old Dec 21, 2004 | 02:28 AM
zelement's Avatar
zelement
I thought the GM LT4 RR are 3/8".
I had a set of the original TFS TW heads. I really didn't like the springs that came with the heads. A set of comp cam LS1 beehive springs and Ti retainers would really lighten things up and make the motor rev more freely. I guess depending on the intake and cam you get you might want to think about switching out those springs and retainers.
Old Dec 21, 2004 | 02:43 AM
conv90's Avatar
conv90
Not, they come with 3/8" studs
..even the CNC version comes with 3/8" studs
-Beppe-
Old Dec 21, 2004 | 02:45 AM
conv90's Avatar
conv90
I'm really interested...
When you have the part# please let me know!
-Beppe-
Old Dec 21, 2004 | 02:50 AM
conv90's Avatar
conv90
No guideplates???
in the Trickflow site on the replacement parts there are
TFS-30400623-8 Guideplates, for use with 5/16" pushrods
88BlackZ-51 Are you sure?
Since I'm purchasing the same heads I have to be sure that they comes with hardened guideplates!
-Beppe-
Old Dec 21, 2004 | 08:23 AM
88BlackZ-51
3/8" studs..
To Trickflow's
Old Dec 21, 2004 | 08:31 AM
88BlackZ-51
Originally Posted by conv90
No guideplates???
-Beppe-
to be honest with you.....guideplates and rocker studs? i have no idea, i mean the head is assembled, but i do see where the studs well thread in, but i dont have guideplates, or maybe i do........got i am tired!
my heads i got do not have the 3/8 ARP rocker arm studs, should they?
Old Dec 21, 2004 | 08:52 AM
conv90's Avatar
conv90
YES! and the guideplates also!
A Summit mistake (as usual...)
-Beppe-
Old Dec 21, 2004 | 08:55 AM
conv90's Avatar
conv90
From summit:
http://store.summitracing.com/defaul...0007+&x=13&y=6
as you can see the guideplates are included and the studs also!
-Beppe-
