Selective ride codes
Old Dec 21, 2004 | 11:14 AM
zr1-2go's Avatar
zr1-2go
Default Selective ride codes
When I pull the codes on the selective ride they all are flashed in order starting with code 12, then on to all the rest. What's it mean?
Old Dec 21, 2004 | 11:18 AM
luvmy92's Avatar
luvmy92
What are the codes being flashed after 12 is flashed 3 times?
Are you jumping A and B, or A and C? For slective ride you need to be jumping A and C.
Mike
Old Dec 21, 2004 | 11:19 AM
zr1-2go's Avatar
zr1-2go
Yes 12 is flashed 3 times.
A and C are jumped.
All the codes are being displayed in numeric order!
Problem solved!
I jumped out pin A to C 3 times to clear the codes then wound up with a code 13 "left rear time out". The actuator was not properly seated on the shock.
Thanks guys.
A manual is in the works. HO HO HO!
To Selective ride codes
