More Turbo Update Pics
I finally got the wastegate put in there. Worked out nicely. I couldn't decide if I wanted to run a strait dump or not, but some of the camaro people said that you'd be able to hear the turbo better this way. But it'll probably eat up a couple of hp doing it. I also got the O2 bung welded on for the wideband.
Here are some shots of the intercooler mounted in the radiator shroud. I don't have a clue where I'm gonna put my tranny coolers now.
And a picture of the intake piping with a boost reference and the IAT sensor. The O2 bungs seem to be universal fit for some of this stuff, a different taper, but some gasket sealant will fix that.
I also finished up the bracket on the bottom of the down pipe. It should take most of the flex out of the pipes when the car is bumping around. It would have been nice to just weld the cross bar onto the pipe, but then there would be no way that I could ever get the pipe out without pulling off the header and/or pulling the engine.
Oh, and here's my new set of toys. I picked up this little setup for $200 shipped. My fuel pressure regulator was leaking gas out of the top so I figured it was time for a new one. Pollished rails, 6an lines, and a custom bracket for the aeromotive regulator, can't go wrong with that. The only problem is that it's made for the later style LT intake so the bolt holes line up but they are just a little smaller. Nothing a drill can't take care of.
Here's the links to my other picture posts.
http://forums.corvetteforum.com/showthread.php?t=958669
http://forums.corvetteforum.com/showthread.php?t=966370
Now I'm all done till january some time. I've gotta build the fuel lines and figure out WHERE I'm gonna put my tranny coolers.
With that being said, I am concerned about your fuel system. The dual -6AN feed and discharge are great, but the discharge necks down to what appears to be a single -4AN return after the regulator. With a decent fuel pump, you will have idle and part throttle control issues, as you will be unable to bleed away enough fuel during the lower injector duty cycle. My suggestion is to upgrade the fuel return from the regulator all the way to the discharge inside the tank.
Are you splitting a -10AN to the dual -6AN on the feed size? If that is the case, -8AN return would be the absolute minimum. What fuel pump are you using to supply the dual -6AN feeds? Many people overlook these sort of details.
Just food for thought.
Aaron
Aaron
I currently have dual walbro pumps and dual 6an feed going to the front of the car. One of the fuel pumps is hooked up to a switch right now and the other is on all the time(nitrous setup) So I'm not sure if I'm going to directly hook them up one to each line or I may put in a double T and keep the second pump turning on only at wot
Double T setup would consist of the incomming fuel going into two lets of one of the t's and going out the third to join them togther(the system would neck down to 6an as a bottle neck but it should be able to flow enough fuel with two pumps pushing it) then the single supply would go into the middle of the second T with the two outlets going to the two fuel rails.
Many people size the feed adequately, but unndersize the return. This works fine at WOT, but creats many driveability/idle issues.
Aaron
I've had a fuel pressure gauge hooked up with both pumps running and the return line seemed to flow enough fuel just fine, even at idle. There was no jump in psi when I would turn the secondary pump on. I don't think I'll have any problems with it, but if I do I'll address them when I know for sure.
Its basically a header dump of sorts...I doubt you'll hear the turbo over it, but I could be wrong. My experience on the muffling properties of turbos says they don't get as quiet as people think...or my Power Effects exhaust really amplifies the sound. When I run them as straight pipes I wear earplugs if Im gonna drive more than 30-40 mins.
I take this car on LONG road trips so the noise has to be bearable. When I say long I mean long, I drove the car from Minnesota to Texas this last summer.
Your making good progress there man. My computer hard drive took a dump last weekend. I was not able to post any pics. I will post some update this weekend. I will be sending out all my pipes to Swain Tech for coating on Monday. We should be fire her up in abour two weeks. I still have complete the ignition conversion to Delteq next weekend. I am also re-do my fuel system, I am doing exactly same as your. Did you read my mind eh?? I am getting rid of my 93 fuel rails due to restriction in side the rail has a 3/8 tubing inside and I don't like how the way the cross over on the 93 rail. But thanks to Rick, he gave me his 95 rails and I just completed plumbing 2 -08AN at the ends of the rail and 2 -06AN with 90 degree on top for return to the regulator and
-10AN feed.
Bruce
-10AN feed.
Bruce
What size return to the tank are you using?
Bruce, Where is Swain Tech? Are you just getting them ceramic coated? Why them, no jet-hot for you? Jet-Hot was the best price I've found so far for strait pipe.
I'm really glad to hear that you're pipes are almost done. And that you'll be hearing the sound of an exhaust rumble within the next month. I've got that pesky rebuild thing in the way, grrrrrrrr.
EDIT: Ok, I looked up Swain Tech. It sounds like they make a nice ceramic coating, but they come right out and say it, it's functional not cosmetic. I definately need some *bling bling* in my engine bay since those pipes are right up top. Not to mention that I don't think they coat the insides, which is what I need with my mild steel.
Even after we coat it, we're gonna wrap the pipes with header wrap. Even the cold side. In addition to a inconel heat wrap over the turbine housing.
As a side note I began beating a giant 5" banjo exhaust. It's pretty damn tough work but it will look sick when Im done. Imagine a form fitting (to the rocker panel) teardrop of stainless opening up in front of the rear tire. Gonna be sweet.
It should support 1000+ cfm with minimal pressure drop, and more with a tolerable pressure drop. Or atleast this is what I was told from the guy that built it.
