1 7/8" headers for an LT1 C4?
Old Dec 21, 2004 | 01:39 PM
ddr698's Avatar
ddr698
St. Jude Donor '09
Default 1 7/8" headers for an LT1 C4?
Im looking at switching from my 1 3/4" TPiS headers to some 1 7/8" headers. The only place I have found so far is Exotic Muscle's. Anyone know of any other manufacters of them out there? I like Kooks but don't know if they make them for a C4? Any help appreciated,
Dan
Old Dec 21, 2004 | 02:18 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
why? what are you doing to the motor that would make you do this change? I went from 1-3/4 to 1-7/8 on my 540ci BB and only shown a few HP difference on the dyno. Not really worth the money if you ask me. but what's done is done.
As for the C4, EM is the only one that "I" know of.
Old Dec 21, 2004 | 02:50 PM
jburnett's Avatar
jburnett
If your engine doesn't need 1 7/8" it will cost you power... That said, the best ones are Jere Stahl's (www.stahlheaders.com). He has them both stepped and straight and they come with the adapter plates I believe. They will fit all of the C4 chassis'.
-Jeb
Old Dec 21, 2004 | 03:15 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
man you have to be pushing some serious power to warrant those beasts!!! You need at least 500+ at the crank to justify that. Check with CFI-EFI regarding this... he'll know a methodical approach to your question.
ddr698's Avatar
ddr698
St. Jude Donor '09
Humm well i was told by several people my combonation might require 1 7/8 headers. Mods are in the signature. Ill be revving around 7500rpm and will have a solid roller cam in the 250s duration range with a lift around .625. The 215RR AFR heads flow ~340 peak at .650 lift. Looking at 600-625 FWHP (i hope ). Will be completely naturally aspirated. Do you think going to 1 7/8 headers are worth it?
Old Dec 21, 2004 | 04:00 PM
jburnett's Avatar
jburnett
YUP... I ran them with my 396/solid roller/single plane and they were worth quite a bit over the LPE 1.75's I had previously run... When you're pulling major rpm and n/a you need some serious exhaust.
-Jeb
Old Dec 21, 2004 | 06:57 PM
red L98's Avatar
red L98
iam using the same heads on my motor , my heads flow little bit more , i had mine angle cut so the valves are a 19 degree head not 23 any more . iam also using the 1 7/8
Old Dec 21, 2004 | 07:39 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yeah, you might actually be able to use them. Especially if you're tuning for mainly high RPM use. My tuner told me I could even use them. I just nodded politely. Don't get me wrong, he's good, if a little eccentric. He tunes cars for Bonneville!
Old Dec 22, 2004 | 02:31 AM
ddr698's Avatar
ddr698
St. Jude Donor '09
Looks like i may look into the Stahl headers but they don't have a 1 7/8" option that allows for hooking up an exhaust system behind it? Humm it is a "street" car so that ill need. Maybe EM 1 7/8"s would be the answer?
Old Dec 22, 2004 | 02:57 AM
zelement's Avatar
zelement
you have a pretty bad setup in your sig. Are you running DFI or FAST?
I think your injectors are too big and you don't really need 1 7/8 headers but that's just my opinion.
Old Dec 22, 2004 | 05:54 AM
TIMSPEED's Avatar
TIMSPEED
Obviously not FAST ENOUGH, if he's wanting bigger headers, right?
Old Dec 22, 2004 | 11:29 AM
ddr698's Avatar
ddr698
St. Jude Donor '09
It supposed to be FAST. For some reason i thought FAST was digital fuel injection and didn't realize when i typed the sig that the term is specific to Accel
Well i wouldn't call it running FAST yet, my AFRs just arrived yesterday after a 10 month wait so shortly I guess It will run shortly. The injector size was picked by the HP formula so i don't think ill have any problems. As for headers im leaning toward 1 7/8" but i dunno.........
Old Dec 22, 2004 | 12:16 PM
AKS Racing's Avatar
AKS Racing
How much are the Exotic Muscle 1 7/8" headers. I have considered replacing mine, but was unaware that anyone made off-the-shelf larger than my current 1 3/4" TPIS headers.
Aaron
Old Dec 22, 2004 | 12:36 PM
STL94LT1's Avatar
STL94LT1
Default Em 1 7/8
$1350
Old Dec 22, 2004 | 12:39 PM
jburnett's Avatar
jburnett
Stahl makes them to fit with an exhaust system... You'll have to fab the exhaust system obviously, the factory style system certainly won't bolt up the the 3.5" collectors. I know they've got them because I built a blown LT1 car a few years ago and used them; then I fabbed a set for my '90 using them as a jig.
-Jeb
Old Dec 22, 2004 | 02:00 PM
ddr698's Avatar
ddr698
St. Jude Donor '09
Humm I think Ill give Stahl a call and get some more info, their website is a lil confusing cuz i also only see stepped headers for the C4.
Humm BTW you may want to double check your valve angles. Im almost positive its impossible to roll over a head 3.5 degrees (the heads are orginally 22.5 degree as advertised by AFR) by simply angle milling them.... correct me if im wrong?
Old Dec 22, 2004 | 06:03 PM
AKS Racing's Avatar
AKS Racing
What was the pricing for the Stahl headers? If enough individuals are looking for the 1 7/8" Stahl headers (with exhaust hook-up), then maybe a group purchase could be arranged.
Thoughts?
Aaron
To 1 7/8" headers for an LT1 C4?
Old Dec 22, 2004 | 11:59 PM
chriswtx's Avatar
chriswtx
I looked into the 1 7/8" headers when building my engine. But the extra cost per HP wasn't worth it to me. Stalh quoted me like $1600 for their headers. The extra $1000 over the cost of 1 3/4" headers for 15-20hp more(if your luckly ) wasnt worth it. Save the $1000 and install a 150 shot of NOS. More bang for your buck. An extra 150hp on top of my 400rwhp for under a $1000, I like that.
Hey Jeb, do you really think its cost effective to use 1 7/8" headers dollar per HP wise?
Old Dec 23, 2004 | 12:04 AM
kwik_ta's Avatar
kwik_ta
That makes a world of difference!!! I think the 1 7\8th's will be of use to you.
Old Dec 23, 2004 | 12:43 AM
Corvette Kid
Stahl's headers are by far the most expensive I have seen for C4s. I think they start at about $1100 and you can get up around 2K in them. Nice pieces, I'm sure, but very expensive HP. They really are only geared toward the very serious racer.
