Piston Experts need help
Old Dec 21, 2004 | 02:05 PM
mothersworry's Avatar
mothersworry
Default Piston Experts need help
Ok I am going to run in the BSP class SCCA in a 1992 LT1. I have had the heads milled .010 and I am going to run the Impala SS head gasket. My current head CCs is 54.5 and with the impala head gasket at .028 compressed my new ccs would be 52.5. Now for the hard part. I can run OE style (same or greater weight and same valve relief as stock) cast or forged. I need my compression to stay at 11.0:1. Does anyone have a piston recommendation to get me there without paying 100 bucks a piston custom made? Additionally a part number would be great.
Old Dec 21, 2004 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
How does the addition of a head gasket reduce the CCs of the cylinder head combustion chamber? Have you figured the CR with the milled heads and the thinner (?) head gasket? For starters...What engine???
RACE ON!!!
Old Dec 21, 2004 | 03:25 PM
mothersworry
The engine is an LT1 and the compression ratio with just the milled heads is 54.5. The head gasket will reduce the ccs by 2. The combined total will be the 52.5.
Old Dec 21, 2004 | 06:28 PM
mothersworry
ttt
Old Dec 21, 2004 | 06:38 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Go here. http://kb-silvolite.com/index2.php They have a nearly unlimited selection of pistons and even if you don't use theirs, you can figure out the specs you need. They also have several different types of CR calculators and lots of other useful info.
Old Dec 21, 2004 | 06:48 PM
CFI-EFI's Avatar
CFI-EFI
There is some wrong stuff here. The compression ratio is 54.5??? Is that 54.5:1??? That would make a diesel jealous. If the heads were milled and that resulted in a 54.5 cc combustion chamber, then the combustion chamber is 54.5 ccs. The gasket can have no effect on the size of the "bathtub" in the head. What are you trying to say?
RACE ON!!!
Old Dec 21, 2004 | 07:05 PM
FD2BLK's Avatar
FD2BLK
Did you cc the head with the spark plug in? Because a normal Lt1 head will cc right at 54.5 with the plug in place before it is milled
Old Dec 21, 2004 | 07:46 PM
CFI-EFI's Avatar
CFI-EFI
If the plug weren't in, he'd still be trying to fill it.
RACE ON!!!
Old Dec 21, 2004 | 10:05 PM
96GS#007's Avatar
96GS#007
Using the following assumptions...
Bore Diameter: 4.000
Stroke: 3.480
Gasket Bore: 4.100
Compressed Gasket Thickness (in): 0.029
Head Volume (cc): 54.500
Deck Clearance: 0.028
Piston Valve Relief Volume (cc): 5.00
...your Compression Ratio would work out to 11.019:1
You don't say if you're retaining the stock bore. If you have to bore the engine, that'll affect CR as well.
An excellent piston to consider without breaking the bank is SRP. I didn't see a standard size p/n listed, but I would think one is available. I bought my rods and pistons from CNC Motorsports. Excellent and VERY fast service. Here's a link to their website:
http://www.cnc-motorsports.com
I'd call them and ask about a standard size SRP piston.
Old Dec 21, 2004 | 10:48 PM
mothersworry
To answer the questions. The heads we angled milled by CNC Cylinder heads .010. Pete told me that the heads CCed at 54.5. Because I am using the impala head gasket I will lower the cc's by 2. Hence the 52.5. Just the nature of the impala shimmed gasket. I will be having the block cleaned and bored 30 over. I must use the stock style piston which I believe is a flat top piston with two reliefs correct?
Old Dec 21, 2004 | 11:03 PM
Corvette Kid
If the '92 piston is like my stock '95s were, they actually have four reliefs so Mr. Goodwrench does have to figure out which way they go!
Old Dec 21, 2004 | 11:17 PM
mothersworry
Thanks Corvette Kid I just looked at them and you are correct they are flat to 4 relief. So with that said, does that hurt or help me finding a piston that works that is not custom?
Old Dec 21, 2004 | 11:31 PM
mothersworry
An additional question. Does anyone know how much the stock LT1 piston weight? I have the service manuals, however cannot find that info anywhere.
Old Dec 21, 2004 | 11:35 PM
Corvette Kid
I'd say at this point, you'll want to get further clarification on the rules you must adhere to. If they allow forged pistons as long as they maintain stock volume, which is 5cc according to 96GS, then I wouldn't think the number of reliefs would matter. I don't think you'll find performance pistons in this exact configuration.
Old Dec 22, 2004 | 08:55 AM
96GS#007's Avatar
96GS#007
As I mentioned before, you should contact SRP or the piston manufacturer of your choice. Here is a piston that's in SRPs on-line catalog:
New Four Valve Relief Pistons
Engine Displacement: 355
Engine Bore: 4.030 (.030 oversize pistons)
Stroke: 3.480
Rod Length: 5.700
Compression Height: 1.560
Valve Relief volume: -5cc
Weight (grams): 460
Piston Part Number: 156505
Piston Ring Part Number: J100F8-4030-5
Application: Claimer Applications Requiring 4-Valve Relief Piston
Old Dec 22, 2004 | 11:00 AM
CFI-EFI's Avatar
CFI-EFI
The gasket is not part of the head. If the combustion chamber in the head is 54.5 CCs. Then it is 54.5 CCs, period. To figure the compression ratio, the head gasket volume is ONE of the items that gets ADDED to the CCs of the heads for the calculation. The gaskets you plan to use MAY be 2 CCs less than the stock gasket, and therefore will contribute 2 less CCs to the total volume than the old gasket in your calculations, but the will NOT change the CCs of the heads from 54.5 CCs. Now... you can do the math.
RACE ON!!!
Old Dec 22, 2004 | 06:30 PM
mothersworry
Thanks for all the help guys. I have finally figured it out. Here we go.
Cylinder Head Volume: 54.5
Piston Head Volume: -7
Gasket Thickness: .039
Gasket Bore: 4.125
Cylinder Bore Diameter: 4.030
Deck Clearance: -.010
Stroke (in.)- 3.48
Puts me at 11.086 compression.
Will this compression be ok on pump gas?
Old Dec 22, 2004 | 07:02 PM
CFI-EFI's Avatar
CFI-EFI
It should be. A lot depends on the cam you use. You will want to record knock counts during competition. That .010 deck height looks rather optimistic, if you haven't decked the block. Of course you won't know for sure until the trial assembly with the new pistons. Even with the .010 deck, you don't have the quench working very strongly in your favor.
RACE ON!!!
To Piston Experts need help
