87 runs rough
Old Dec 22, 2004 | 08:40 PM
ovhd's Avatar
ovhd
Default 87 runs rough
My buddy has my old 87 that i sold to buy a zr1. The car has about 70 k miles and i owned it for 10 years before i sold it to him. Its been well taken care of but he is telling me at idle it runs rough and the check engine light is on. Once driving its fine. Anyone have any ideas why its running rough??
Old Dec 22, 2004 | 08:42 PM
Pete K's Avatar
Pete K
1st step is to check the codes
Old Dec 22, 2004 | 08:44 PM
ovhd's Avatar
ovhd
just jump the 2 pins under the dash does anyone have the codes.
Old Dec 23, 2004 | 02:47 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I'll Bet it's a code 34 EGR VALVE!
Take a paper clip and on the right end of the diag moduel install paper clip between the last two pins and turn on the key and count the flasher.
First will be one then two flashes or 12 and it will do it 3 times for each code just wait, this means the computer is working,then it will flash the next code and it will be 3 times and jot down the flashes .
Old Dec 23, 2004 | 08:31 AM
rick lambert's Avatar
rick lambert
To many things it could be. Once you get the code let us know and we'll try to help. And don't rush out to buy parts-even if it is the EGR-because usually it's just the switch.
Old Dec 23, 2004 | 08:41 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
He needs to pull the codes as step one.
If it is the dreaded EGR code 32, there is a diagnostic method on my site to isolate the faulty system component.
Old Dec 27, 2004 | 11:31 AM
ovhd's Avatar
ovhd
Default code 34
my buddy jumped out the computer and he has a code 34. Should he change the egr and switch or troubleshoot some more.
Old Dec 27, 2004 | 03:03 PM
rick lambert
the Egr switch cured mine, and I've hears it said on the forum that it's likley the switch 95% of the time. It's also very cheap and easy to install-I ended up splicing mine simply because it plugs in down and behind the distributor.
Old Dec 27, 2004 | 03:22 PM
MR.KIDD's Avatar
MR.KIDD
If I am not mistaken code 34 is maf issues.
Old Dec 27, 2004 | 05:32 PM
87SAM's Avatar
87SAM
34, MAF low air flow. Since it has a rough idle, check IAC & TPS
Old Dec 28, 2004 | 01:04 AM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Simply time for a tune-up? Cap/rotor/plugs/wires??
To 87 runs rough
